Tip & How-To about Epson Office Equipment & Supplies
Epson printer not printing
I could not get my epson printer to print and found out that i forgot to remove the cartridge pastic tab and it fell below cartridges... take all cartridges out shut off and turn on look in bottom and saw tab now printing fine .....
put new ink cartridge in wont print epson sx110
hi
make sure you removed the protective plastic tab off the cartridge before installing it -- remove the cartridge from the printer , look at the top and make sure the tab has been removed, reseat the cartridge and try again. if there are other cartridges, remove them, -- shake the cartridges and reseat them.
if this failes , refer to your manual
Feb 07, 2011 | Epson Stylus Multifunction Inkjet Printer/...
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access maintenance
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
how to print using black ink only on Espon dx5050?
Did you use Epson Genuine Cartridges??
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you have Genuine Epson Cartridges, and have ink in ALL THE CARTRIDGES, to print in black only, Make the following settings on the control panel. SEE BELOW:
Select the number of copies.
Select l [Plain Paper].
Select the paper size you loaded.
To make a color copy, press the
x StartE[Color] button.
To make a black-and-white copy,
press the x Start D [B&W] button.
If you find this information helpful, pls rate me.
You can download the entire manual. Just click on link below. I found on the web:
http://safemanuals.com/314159.php?k=3c8871ac74c76c7b6bdba73063efb872&ID=552849&q=EPSON%20STYLUS%20DX5050
Thanks and Good Luck
and pls rate me.
Feb 16, 2010 | Epson Stylus DX5050 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
1,760 people viewed this tip
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
