Tip & How-To about Search with google Search Google with Friends
How to find a manual for a product on google
Open your browsers search box, then type the name / make & model of your product...Then put .PDF on the end & you will always get the pdf files in the search results, which is the format that most manuals are in....
if you still cant find what your after.........then go to the manufacturers web site & then into the Support / Downloads section & again put model number in, or pick it from a list they supply you with......DON'T EVER PAY FOR ONE ! their out there if you look.
Search with google Search Google with Friends Logo
i need the manual for my NP900X30 laptop
see the samsung support website for a full pdf copy of your manual
Jun 10, 2014 | Samsung N Computers & Internet
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
need the manual for a L3HMAY97FANHD
go to the manufacturers website . manuals of free downloads in the pdf format [portable document format] you will need the make & model # of the fan. to the manufacturers website go to google.com
or bing.com or ask.com and type the manufacturers name in the search box and click search.
when you get to mfg website ,look for download owner's manual
and look for your model # in the list or type your moddel # in the search box.
Dec 04, 2012 | Hampton Bay 24002 Ceiling Fan
Hi, I cannot print a pdf file or that kind of attachment. Only Word can print. Adobe error shows up and want to shut down the program for protection. I never had the problem before. Just started.
Is it a file that you created in pdf format, or is it one that you have had emailed or attempting to open from another source? Some pdf files have protection put on them by the file originator to avoid the file being changed/printed. Here are some tips to try to get them to print for you.
  1. Open your computer's Internet browser.
  2. 2
    Type www.a-pdf.com/security/a-pdf-rr.exe in the browser's URL box to access the PDF restriction converter "A-PDF Restrictions Remover."
  3. 3
    Press the "Enter" or "Return" key. Your Internet browser will access the site's PDF converter file. A dialog box will appear on your screen--"Opening a-pdf-rr.exe."
  4. 4
    Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer for running later--use this option if you using a slow connection like dial-up. The program will download and set up on your computer if you selected the "Open" or "Run" option.
    If saving the file to your computer, navigate to the directory where you want to save the file to. Select the "Desktop" if you have a hard time locating downloaded files on your system.
    You do not have to access the A-PDF Restrictions Remover website again once the file starts downloading or saving to your computer.
  5. 5
    Double click on the "a-pdf-rr.exe" icon to open the program, if you selected the "Save" or "Save As" option.
  6. 6
    Click "Run" when prompted with the "Open File -- Security Warning."
  7. 7
    Click "Next." Click on the circle by the wording "I accept the agreement." Click "Next."
  8. 8
    Select the directory where you want to save the "A-PDF Restrictions Remover" file. The default is your "C:\Program Files\A-PDF Restrictions Remover" folder. Click "Next."
  9. 9
    Click "Next," "Install" and then "Finish." A-PDF Restrictions Remover will start automatically.
  10. 10
    Navigate to the directory where the protected PDF file is located.
  11. 11
    Right-click on the PDF file name. Select "Remove Restrict & Save As."
  12. 12
    Select a location to save the converted PDF file to. Click "Save." If you want to change the PDF file's name, enter a new name in the box next to the wording "File name." The protected PDF is now converted to a unprotected one.
  13. 13
    Double-click on the converted file to open it.
  14. 14
    Select "File," "Print" and then "OK" to print the unprotected, converted PDF file.
  15. Printing a Protected PDF By Taking a "Screen Shot"
  16. 1
    Open the protected PDF file2
  17. Press the "Alt" and "PrtScrn" keys together. The PrtScrn key is located on the upper right-hand side of your keyboard, if using a desktop computer keyboard. If using a laptop, the PrtScrn key is located above the "F10" function key.
  18. 3
    Open your computer's word processing program by clicking on the program's icon on your system's "Desktop" or from the "All Programs" menu.
  19. 4
    Press "CTRL" and "V" keys together to paste the screenshot into a blank document.
    If using a Mac, click "Edit," "Paste" from the main toolbar at the top of your word processing program.
  20. 5
    Click "File," "Print" and then "OK" to print the PDF screenshot. If the protected PDF file contains more than one page, press the "PgDn" key and repeat steps 2 through 5.
Oct 29, 2010 | Canon FAXPHONE L80 Laser
Can't get rid of bloodhound pdf 8 and now I can't get into my user profile
You are going to have to get your hard drive wiped and windows re-installed then you will be able to have your computer up and running again!
May 07, 2009 | Computers & Internet
660 people viewed this tip
Top Search with google Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Search with google Facebook App Expert? Answer questions, earn points and help others
