Tip & How-To about Apple iPhone Smartphone
How to add Songs on iPhone without a PC & iTunes
One of the few things that disappoint me about the iPad is that Apple's flagship tablet is still, to some extent, dependent on a nearby computer and an open window of iTunes or WinSCP. Bridge is a Cydia app which makes importing files to your iPhone, iPad, or iPod Touch without a computer an easier affair. While there are many apps and tweaks that can get content on your phone, Bridge has a special feature which makes it worth the $1.99 asking price.
We've already covered a number of methods to download programs to an iPhone, iPad, or iPod Touch without using iTunes. Some of the free methods include OpenSSH (for secure wireless file transfers from a computer), iTransmission 2 (for torrents), and Safari Download Enabler (for downloading links and video files from the web). The problem is that while these apps and tweaks are more than capable of loading music on to your phone, they don't add the files to the Music app. This means you can't make playlists with the songs you've just loaded onto your phone.
That's where Bridge comes in. With Bridge, you can locate the files you've downloaded to your device and properly import them into your library. You can use this to load Songs, Ringtones, and Podcasts for audio files, set album artwork from your photo roll, and also import movies.
Applying album art to an imported song in Bridge
The only downside is the music won't be transferred back to your computer by syncing through iTunes. That's not a limitation of the app, but a limitation in iTunes. It wasn't built to transfer user-loaded music to your computer from an iPod. If you ever need to import music to your computer, you can use SSH to copy the music over. The files should be stored in 'var/mobile/media/music'.
Bridge can be found in the BigBoss repository on Cydia. Share your thoughts in the comments section below.
Apple iPhone Smartphone Logo
my ipad has been disabled
Just plug it in via the supplied cable (if you don't have iTunes installed on your computer you can download it from here) - you should then be able to reset the iPad, but as you haven't synced it to a computer before then you won't be able to restore to a backup from the computer. You may need to put the iPad into recovery mode in order to be able to reset it : http://support.apple.com/kb/ht1808
Have you ever backed up the iPad to iCloud ? If you have then you should be able to restore to that backup after you've reset the iPad via a computer.
You can also re-download some/all of your iTunes purchases (what you can re-download depends upon what country that you are in) :http://support.apple.com/kb/HT2519
Jul 22, 2014 | Apple iPad (16 GB) WiFi Tablet PC
snow screen
This sounds like a hardware failure, which means you need to take it to the Apple shop. First, you may however try one more thing: Hold down the Sleep/Wake button and the Home button simultaniously for 10+ seconds, this will cause a reset. If this works, try and restart the iPad and give it a few minutes to finish loading. If it will not restart, you could try to connect it to iTunes in your computer and restore it, replacing the system.
Good luck! :)
Apr 25, 2014 | Apple iPad (16 GB) WiFi Tablet PC
i pad frozen on apple logo
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore: pad-frozen-apple-logo-of1o0fkyrymqaiqlgkygvvrr-4-0.jpg pad-frozen-apple-logo-of1o0fkyrymqaiqlgkygvvrr-4-2.jpg Restore iPad to new factory condition
Apr 01, 2014 | Apple iPad (16 GB) WiFi Tablet PC
download ios 6.0
depends on the iPad model you have:
For the iPad first generation (A1219) before iOS5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- but this model supports only iOS 5 !
- NO iOS 6 / 7 / 8
download-ios-6-0-1y0lj1fh1owk11gcm323dzua-5-0.jpg download-ios-6-0-1y0lj1fh1owk11gcm323dzua-5-2.jpg download-ios-6-0-1y0lj1fh1owk11gcm323dzua-5-5.jpg download-ios-6-0-1y0lj1fh1owk11gcm323dzua-5-14.jpg
Jan 23, 2014 | Apple iPad (16 GB) WiFi Tablet PC
forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
1,381 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
