Tip & How-To about HP Officejet Pro X476dn Color Inkjet All-In-One Printer, Copier, Scanner, Fax
Resetting an OfficeJet X-series Printer
Since this printer has no physical buttons, but a touch screen display there is a special way to get into service mode
Right after applying the latest firmware upgrade on a brand new HP X476 printer, All of the admin functions displayed a padlock icon, they were locked and requested an admin password. Since I had just gotten the printer, got it networked, and all the preferences set, I had not created an admin password. The update assumes you had set it and locks all of the admin functions. So I had no password set, therefore there was no password after the update. So I could not do a reset as it is protected.
After over and hour with HP Support (his name was "Bob" with a very heavy Indian accent) I got them to "give up" the way to get into the service mode to do a hardware factory reset.
Warning: There are functions in this mode that are meant for service technicians and can cause major damage. We all like to "tinker" but I strongly suggest you stick to the reset functions only.
Start from the home menu on the printer's screen. Press the "return" icon. It is not illuminated at this point. You can display it by pressing one of the main icons (copy, scan, fax, apps) and mark where it is. Press it 4 times. The servfce menu appears. press down until you get the reset menu. Select the partial reset. That should reset the printer to factory defaults.
HP Officejet Pro X476dn Color Inkjet All-In-One Printer, Copier, Scanner, Fax Logo
how can I reset my printer
After you have cleared the jam, make sure you
press the control panel back into place. You may also need to remove any jammed
paper from the rear access door or from inside the device.
Nov 22, 2014 | HP Officejet 4315v All-In-One InkJet...
cannot open the printer
AC driver PCB problem !
PCB needs to be replaced
Nov 10, 2013 | Xerox DocuColor 12 Printer
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
same issue here
Make sure the unit is in copy mode. Press '#' then the Interrupt key, the 'C' button, then the Interrupt key again (sequence #-Interrupt-C-Interrupt). This will put the copier into Service mode.
Enter the number 22, then press the Start key. Now enter the number 7 and again press the Start key. This will display the existing security code for key operator (special) settings.
Aug 28, 2009 | Sharp AR-235 Copier
need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
1,996 people viewed this tip
mukhtar21 shaikh
mukhtar21 shaikh
