Tip & How-To about Apple iPhone Cell Phones
How to Transfer Contacts from iPhone to Computer
Your iPhone keeps the important data for you, contacts, for example. There is the possibility that you want to transfer the contacts from your iPhone to computer as backup, and this guide will show you how to export contacts from iPhone.
Method 1. How to Export Contacts from iPhone 6 (Plus) with iCloud
This requires you to sync your contacts to iCloud, then go to icloud.com to export the contacts to your computer.
Step 1. Go to "Settings" on your iPhone 6 (Plus). Select "iCloud", then enable "Contacts" by toggle it to On position.
Step 2. On your computer, go to icloud.com and log into with your Apple ID.
Step 3. Click on the "Contacts" to access your address book, click on the gear icon at the lower-left portion, click "Select All" and "Export vCard" to export contacts to your computer.
Method 2. How to Export Contacts from iPhone 6 (Plus) with AnyTrans
Step 1. Download and install AnyTrans on your PC/Mac. Launch AnyTrans, and connect your iPhone 6 or 6 Plus to computer.
Step 2. On the homepage of AnyTrans, click "Contacts", then go to the contacts manage page.
Step 3. Preview the contacts, and choose the items you want to export, and click the To PC button to export iPhone 6 contacts to computer.
Resource from: How to Export Contacts from iPhone 6 Plus
Cell Phones Logo
how to transfer contacts from iphone to pc?
I had a nokia E71 and downloaded software from the NOKIA WEBSITE. you can use it to transfer your nokia contacts into windows contacts.
Then you have to download Itunes from APPLE and use CLOUD SYNCH to send your windows contacts (which would have your nokia contacts intergrated) to your iphone. I used the charger and plugged into the USB of the computer for both. its alot of work but possible - and faster than manual re-enter.
note: some contacts on my nokia for example if a phone number description was changed from "work" or "home" to lets say "work cell" windows contacts did not understand custom categories and some numbers did not transfer correctly, eg, "work cell" became "fax" or nothing at all. There was some editing within windows contacts to correct the issue so that Itunes would interpret the contacts correctly.
In short:
-Nokia software
synch contacts to windows contacts
-windows contacts
check everything looks good
-itunes & cloud synch software
import windows contacts and synch phone.
(Cloud synch may be a separate download)
as far is I know there is not an easier way.
Dec 14, 2012 | Apple iPhone Smartphone
transfer calander and memo to i phone from palm desktop
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Oct 18, 2009 | Apple iPhone 3G
Transfer contacts and calendar from Palm to iPhone and iCal
Two examples are:
Oct 04, 2009 | Palm Tungsten E2 Handheld
I have a Palm Zire 31 that I want to transfer all my information to my Iphone. How do I do that? I spoke to Apple and the way they showed me didn't work.
Two examples are:
Sep 26, 2009 | Apple iPhone Smartphone
1,256 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
