Tip & How-To about Industrial Paper Shredders Office Equipment & Supplies
How to save repairs for paper shredders
When purchasing a new paper shredder, analyze your needs and purchase the largest shredder to fit your need and budget. If you buy one that "says" it can handle 10 sheets at a time, only put 6-7 sheets at a time to prevent overloading your shredder. Always use shredder oil to lubricate your blades and that will also prevent binding and eliminate most jams.
do you ever need to lube a memorex paper shredder
ALL shredders need to be lubricated. When metal turns, it creates friction that, over time, can cause the blades to warp. Just like you have to add oil to a car, shredders must be oiled as well. You can buy bottles of oil at your local office supply store. Just squirt across the top of the blades. Or pour some on a plate, dip a piece of paper in it, then shred. If you want less mess, purchase the pre-lubricated sheets that you can just drop in and shred. Make sure to shred in reverse about half way through to get the best results.
Apr 18, 2014 | Memorex MPS-2800 5 Sheet Cross Cutt Paper...
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Feb 19, 2008 | Office Equipment & Supplies
437 people viewed this tip
Top Industrial Paper Shredders Office Equipment & Supplies Experts
Gilbert Ruiz
gdta
Level 1 Expert
Danny Kuhlmann
Are you an Industrial Paper Shredders Office Equipment and Supply Expert? Answer questions, earn points and help others
