Tip & How-To about Samsung Dishwashers
Fixing 5E or SE error code on Samsung model Dishwasher
Our 13 month and very expensive Samsung dishwasher model DW80F800UWS stopped working and displayed error code 5E or SE if you don\'t know they all start with a number (which I did not). After 2 weeks of pain with "repair man" an fixed it myself and I wanted to share my success story.
This dishwasher uses an optical sensor to detect how much water is in the tub body. Older dishwashers use a simple float but Samsung had issues with these sticking open so they must have switched to the solid state sensor at some point. Believe it or not if the sensor gets dirty with gunk from food the sensor false reads that there is still water in the tub and shuts down with error code 5E. The sensor is removed from the right side access panel (when looking at the machine from the front. Its a small round clear plastic sensor held in with black plastic clip. Take it out and clean off the gunk. Re-install and wham bam thank you mam!! Your wife will think your a genius!! total cost of repair is Zero...yes that right ZERO!
Part number for this sensor is DD32-00003A and you can use the Sears website to see the diagram and location. Here is the link
http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dishwasher-Parts/Model-DW80F800UWSAA0000/1482/0130000/Q0042928/00006?blt=06&prst=&shdMod=
I wish I would have done my homework first as I had a failed service call before I fixed it myself! Cost me some money I hope others can avoid!
Dishwashers Logo
how to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
se code Samsung DW80F800UWS What should I look For?
Theres a 5E I can't find a Se
Nov 22, 2014 | Samsung 24 " Built-In Top Control...
SE display code on a Samsung Dishwasher
The SE (or actually 5E) error code means "drain error". Most often, this is caused by a blocked or clogged drain hose, or something hard getting inside the drain pump that is blocking or impeding the free operation of its impeller. If all that is okay, then you may have a bad ECS sensor.
Jun 17, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
2,382 people viewed this tip
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
