Tip & How-To about Samsung GALAXY S4
How to Mute Sounds Using Your Hand on the Samsung Galaxy S4
1) Go to the Settings app. Look for the gear icon and tap it.
2) Tap on the "My device" tab at the top to access your device settings.
3) Scroll down with your finger and tap on "Motions and gestures". It should be under the "Input and control" section.
4) Tap on "Palm motion". If it's not already done, activate the feature by sliding the switch until it turns green, first.
5) Activate the "Mute/Pause" feature by sliding the switch.
  • Optional: If you'd like, you can play the tutorial by tapping the text.
Samsung GALAXY S4 Logo
how do you clear data from memory
Clear cache or data for individual apps
  1. Open your device's Settings app .
  2. Under "Device," tap Storage.
  3. Tap Apps and choose the app.
  4. Tap Clear data or Clear cache.
How do you delete memory on your phone? Follow these procedures to clear your cache.Go to your Home Screen. ... From your Home Menu, tap on the Apps icon. ... From the list of applications on your phone, tap on Settings. ... From Settings, go to Application Manager. ... Open each application on the list and tap on Clear Data and Clear Cache.
quoted from Google.
Jun 16, 2017 | Office Equipment & Supplies
My phone keeps on displaying this massege:- "unfortunately, the process com.google.process.gapps has stopped." how can I solve it
Hi the gapps in the error refers to Google apps ENABLE THE DOWNLOAD MANAGER..step 1 : tap on apps ..step 2: tap ,& drag the application screen towards the right to access settings ,& then tap on settings icon 3: tap on more 4: tap on application manager under more tab. 5: now tap & drag the application manager screen towards left and access DISABLED application ( note if disabled tab is not available.go TO ALL TAB,) 6,: tap on download manager with Android icon. 7: tap on enable now Download manager is enabled ( disabled should B on screen ) ...8 restart you're device ...good luck
Jun 19, 2016 | Tablets & eReaders
HOW DO I CHANGE THE LANGUAGE?
  1. Swipe down from the top of the screen to access the notification tray.
  2. Tap the settings gear icon in the top-right.
  3. Tap the My Device tab at the top.
  4. Tap Language and input under the Input and control subheading near the bottom.
  5. Tap Language at the very top.
  6. Tap the language you'd like to switch to.
Nov 05, 2015 | Samsung SGH Cell Phones
how do I adjust brightness level on reading page of my kindle app
Fixing the brightness of your screen is easy on the Kindle Fire, Kindle Fire HD and Kindle Paperwhite, all of which provide screen brightness controls. This feature is not available on the original Kindle, however, as the screen is not backlit.
Kindle Fire Step 1 Tap the "Quick Settings" icon in the upper right corner of your Kindle screen. The icon looks like a gear.
step 2
Select "Brightness" from the Settings menu. If you don't see it immediately, tap the "More" icon to access all of your settings options.
step 3
Use your finger to toggle the slider from left to right to increase or decrease the brightness of your screen.
Kindle Fire HD and HDX Step 1 Slide your finger downwards from the top of the screen to display the Quick Settings menu.
step 2
step 3
Toggle the slider to the left or the right to fix the screen brightness.
Kindle Paperwhite Step 1 Select the lightbulb icon on your Kindle screen. This icon is present when you're reading a book.
step 2
Move the vertical slider with your finger to achieve the ideal screen brightness.
step 3
Tap and hold the "+" sign to achieve maximum brightness. To achieve the lowest brightness possible, tap and hold the "-" sign.
Jan 05, 2014 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
how do i change languages?. I'm stuck in Italian
  1. Open the "Impostazioni" app (Settings in Italian), denoted by the three gears icon.
  2. Tap on the "Generali" (General) tab (which shares it's icon with the settings app) to open it.
  3. Scroll down and open the "Internazionale" (International) menu.
  4. Tap on "Lingua" (Language) and select "English" from the menu.
  5. Tap the "Fine" (Done) button.
  6. Wait for the iPod to load the new language.
You will also want to disable the Italian keyboard, which can be accomplished as follows:
  1. Open the "Settings" app.
  2. Tap on the "General" tab to open it.
  3. Scroll down and open the "International" menu.
  4. Tap on "Keyboards" and tap the "Edit" button in the upper-right corner.
  5. Tap the red minus sign next to the "Italian" item, and then tap the red "Delete" button that appears.
Here's how to change languages while the iPod is set to English
  4. Tap on "Language" and select "English" from the menu.
  5. Tap the "Done" button.
Dec 27, 2010 | Apple iPod touch
2,023 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
