Tip & How-To about Samsung Galaxy S Iii S3 Gt-i9300 16gb Marble White Gsm Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 - Pre-order
How to Reset a Samsung Galaxy S3
1) Tap "Menu" from the home screen.
2) Tap on "Settings."
3) Select "Back up and reset."
* By default, your device will automatically backup and restore all your data. If you do not want your personal data backed up and restored following the reset, tap on each corresponding option to clear the check box.
4) Tap on "Factory data reset."
5) Tap on "Reset device."
* If you have the screen lock feature enabled on your device, you will be prompted to enter your password or PIN code before you can continue.
6) Select "Delete all." Your phone will then reset by wiping all data and rebooting
Samsung Galaxy S Iii S3 Gt-i9300 16gb Marble White Gsm Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 - Pre-order Logo
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
how to hard reset samsung sgh-a817
Hard Reset - This process will reset the setting as well as erase all your personal data and downloaded content.
Note: if you have any data that you feel you need to keep please back up before proceed with the below steps. Once the data is gone it is gone forever.
1. Go to the Home screen.
2. Press on the Menu.
3. Next tap on the Settings.
4. Then tap on the Phone option.
5. scroll down the screen and then tap on Restore Phone.
6. Now tap on Yes to confirm.
7. Put in the password and tap on the Confirm button. Do this again to confirm the password.
8. Wait for your phone to reboot and check out if the setting has gone back to default.
or you can do this also...
1.Go to the Home screen.
5. Next tap on Reset Phone.
Oct 01, 2012 | Samsung Sgh A817 Solstice Ii - Black...
how do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
how do i do a master reset for a LG GS 390
Try a hard reset (it will clear all data and configuration settings, suggest backup first)
- Select Main Menu from the Home screen Tap Settings
- Scroll to and Select Phone Settings
- Scroll to and Select Reset Settings
- Tap Master Reset
- Tap Yes to confirm
- Enter the device's security code, then tap OK. (The default security code is 0000)
Jun 17, 2011 | LG Cell Phones
locked out of a samsung seek SPH- M350 and wondering if there was a way to hard reset it.
To Hard Reset Samsung Seek to Factory Default Setting: 1. From Home menu screen > Main menu tab, located at the bottom 2. Tap Settings 3. Scroll down to the bottom of your cell phone menu 4. Tap Reset 5. Tap Reset Settings 6. Read the statement displayed then Tap Proceed 7. Enter the 4 digit number then Tap Done If you want to unlock it
Apr 03, 2011 | Cell Phones
2,075 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
