Tip & How-To about Heating & Cooling
Carrier Weathermaker 9200 Gas Furnace Error Code 31
A month or so ago, I woke up to discover that I had no heat in my house. I went to the furnace to do a diagnostic check, removed the service door and quickly discovered that there was no flame (visible through the glass peep-hole).
I followed the manufacturer's shut-off procedure, which can be found in the manual, here: http://legalectric.org/f/2011/03/carrier-9200-weathermaker-uhe-om58-67.pdf. When I turned the furnace back on, I saw that the igniter did not glow (should be visible through the same peep-hole - should look like a red-hot, 2-prong tuning fork) and that the red LED error code indicator (visible through the lower peep-hole) was blinking 3 short flashes and 1 long flash (error code 31).
Now what I SHOULD HAVE done was check the pressure switch first (see service manual pg. 3, component #16). By removing the rubber lines that connect tot the pressure switch, one end at a time and both at the pressure switch and the bottom of the igniter box, you may notice some debris in the lines or the male adapters on the pressure switch or igniter box. If you do, clear out the debris with a paper clip (don't insert the paper clip into the body of the pressure switch, though). After checking all connections for debris, disconnect the hose that connects to the top of the pressure switch at the "T" between the pressure switch and the igniter box and blow/suck air in and out of the pressure switch (lightly). If you hear a small click when you pass air in and out, that's the pressure switch functioning. If you hear crackling or you can't blow in/out easily, you probably have a bad pressure switch.
if you are able to make the pressure switch click, connect all lines and start up the furnace per the mfg recommendations. If the furnace kicks on, it was probably a blockage in the pressure switch lines (likely if you found gunk in the lines or male adaptors on the pressure switch), but it may still be a faulty pressure switch (my problem... when I blew in and out to the pressure switch, I could hear the silicone diaphragm cracking). I got mine going, albeit temporarily, by removing the pressure switch and passing air in and out (blowing pretty hard) with my lips on the bottom hose adapter until I could hear the diaphragm crackle free and it became easier to make it click on and off. That only bought me a few days, though. After that, I bought a replacement pressure switch at a plumbing supply place and replaced the old one. If you found gunk in the lines, I would suggest you have your furnace serviced and let the tech know what you found and where.
If neither procedure fixes the problem, it may be the igniter. For some odd reason, this issue started for me about a month ago and I replaced the igniter (YouTube video instructions are easy to find), which fixed the problem. If even that doesn't work, call a local tech, shut the gas off and wait around in some thick blankets! I hope this helped!
Heating & Cooling Logo
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
gas backup wont light. repairman said need new heat exchanger. approx 60 days ago replaced all burners and it woked ok they got it running for 1 night now it is out again. if the xchanger is bad why did it work for 1 day? thanks ron
I would only assume that now you have taken out an over heating sensor. When a heat exchanger goes bad it is a very dangerous situation because now you are pumping carbon monoxide in your house along with your heat. A heat exchanger is a baffle that hot gases pass thru, heating up the exchanger along the way and expelling carbon monoxide out the exhaust/chimney. Bad exchangers crack along seams or burn holes thru allowing the exhaust to mix with the blower air and in time this could cause carbon monoxide build up in your house. This cracking also lets hot exhaust in to the furnace and can burn up over heat protection, wiring and possibly cause a house fire. Please change out the heat exchanger or entire furnace, there is no price to replace a human life.
Dec 20, 2010 | Heating & Cooling
GDS80904BNA Goodman furnace only cylces off for a minute
Sounds like your repair man ripped you off. He should have stood behind his work.
1. I would try to clean the flame sensor located just below the burners. It is connected to "one" wire (Not the two wire) clean rod with sandpaper.
2. The old and thermostat could have a had a bad heat anticipator. if the new t/stat is not digital the heat anticpator on the T/stat needs to be adjusted. slide the small adjuster arm under the cover to about .6 or .7 and see if the solves the problem. if the t/stat is digital it should be preset from the factory.
3. last resort have a service man check your pressure swith. could be a slow inducer motor, blocked or bad vacum line, or a restricted drain or flue pipe.
Mar 02, 2009 | Goodman GDS80904BNA Open Flame Heater
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
595 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
