Tip & How-To about Dometic Refrigerators
How to Change a Dometic Cooling Unit
This video will walk you through the process of changing you cooling unit.
Contact Arcticold toll free 1-888-782-6665 or visit our online Store
Refrigerators Logo
can we recharge freon
These type of refrigerators can not be simply recharged as there is ammonia inside and not freon.
The cooling units can be replaced tho. Most systems can be changed out in a matter of just an hour or two. Our Replacement units come standard with install instructions and a lifetime warranty. Check out our online Store
Toll Free ph 1-888-782-6665
check out our video on how to change a cooling unit
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic 2932641034 Refrigerator Part Front...
refrigerator not cooling
I have attached a Video to help Diagnose the problem.
You can also give Arcticold a call to help diagnose the problem free of charge, (toll free 1-888-782-6665) ArctiCold Refrigeration We keep it cold 83eb4fa1-372f-4675-9cc8-83b8dd2308bb.jpg
Mar 15, 2014 | Dometic Refrigerators
dometic DM2652 quit working on elec,tried gas worked for a little than quit,wont cool can hear it running.
If you can hear it running and it sounds like it is gurgling or boiling then it is you cooling unit that has leaked. Your cooling unit is charged with hydrogen and ammonia. When the hydrogen leaks it causes the ammonia to boil more rapidly, hence what you hear. You will require a new cooling unit for your refrigerator. This is something that can be done by anyone in just a few hours with no specialized tools needed. You can give Arcticold a call toll free (1-888-782-6665) or check out our online Store I have also attached a how to video for the installation of a Arcticold New Lifetime Warranty cooling unit. 3a202669-372c-42db-9d46-dcb343b69e0b.jpg
Mar 11, 2014 | Dometic RM2620 Refrigerator
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
not cooling yellow chemical in outside compartment
Any sign of yellow residue on the rear of an RV Fridge means that you require a replacement cooling unit. It is something that can be done by most RV owners. Ive attached a video that will walk you through the install of your cooling unit. The video is by ArctiCold Refrigeration We keep it cold The cooling unit can be purchased aftermarket at Arcticold's online store. www.arcticoldstore.com
Store
Feb 11, 2014 | Dometic RM2852 Refrigerator
1,451 people viewed this tip
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
