Tip & How-To about Cfm 802 Ecofan Table
Clean the device
I used an air compresser at 50 psi to blow the dust out of the crevases and then through the back of the fan motor to return the 2 year old unit to like new operating condition.
Hold the blade while doing this so you do not over spin the fan.
I suspect the dust in the motor was sapping the low voltage electricity being generated by the device. House dust buildup causes faults in circuit boards p. Carbon will cause arcing; soot is pure carbon,
Try this before a rebuild.
Cheers,
Mike
Cfm 802 Ecofan Table Logo
aspire 5742 i3-370m overheating how do i fix it
Three things that will make a laptop overheat:
1. Dust - Dust inside the laptop, dust clogging the vents, dust around the fans, dust around the cpu and heatsink. To fix it, take the laptop apart, take a can of compressed air and blow out the dust.
2. A fan is not working. To fix it, you will have to take the laptop apart to replace the fan.
3. The Thermal Paste around the cpu and heatsink has dried up or is too thin to keep the unit cool. To fix, take the laptop apart and apply a fresh coat of Thermal Paste.
Another work around for a laptop that is overheating is to by a Laptop Cooling Pad that has fans on it and it plugs into the usb port of the laptop. The laptop sits on it and it keep the laptop cool. You can buy a laptop cooling pad for less than $20 from Tiger Direct.
http://www.tigerdirect.com
When the site opens just type Laptop Cooling Pad in the search box at the top of the screen then press GO. Sort the returned results by Price Low to High.
May 16, 2012 | Acer Computers & Internet
Denon AVR 883 no sound from any source including zone 2 speakers
This sounds like a thermal issue, meaning after the receiver has been on for a while it gets to warm and then fails. I suspect after 8 years the unit may have accumulated some dust that is not allowing the heat sinks to dissipate heat adequately. I would use compressed air and blow the unit out. Some computer stores have blow stuff in a can that work well. If you have and air compressor, dial it back to 10 psi or so. You will be amazed at how much dust will come out of that unit so you may want to unhook the unit and take it outside. Also be careful not to stack anything on top of your receiver. Make sure there are lots of openings around the unit. High temperatures kill electronics.
Hope this helps.
Apr 03, 2010 | Denon AVR-883 Receiver
I have a 10 year old Receiver. I have a DVD player connected and the picture does not display when the receiver is running for a period of time.
This sounds like a thermal issue, meaning after the receiver has been on for a while it gets to warm and then fails. I suspect after 10 years the unit may have accumulated some dust that is not allowing the heat sinks to dissipate heat adequately. I would use compressed air and blow the unit out. Some computer stores have blow stuff in a can that work well. If you have and air compressor, dial it back to 10 psi or so. You will be amazed at how much **** will come out of that unit. Also be carful not to stack anything on top of your receiver. Make sure there are lots of openings around the unit. High temperatures kill electronics.
Hope this helps.
Apr 01, 2010 | Denon AVR-1801 Receiver
how to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Mar 22, 2009 | Dryers
651 people viewed this tip
Top Cfm Dryers Experts
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
