Tip & How-To about Nextbook Tablets & eReaders
How to factory reset (restore) your nextbook
Make sure you start with the nextbook powered off
first hold the volume + button and then hit the power button and continue to hold both for about ten seconds (give or take;more than likely give a few more seconds) when the opening screen or start screen appears wait a bit more until it goes black once it goes black then release the power button. what you should see next is a few lines on the top of a black background with options listed on what you can do next if you are here for a reset to factory then you will use the volume - button to move to the line that indicates factory reset. once selected the line of choice you will hit the power button which will cause it to reboot or there may be a few more questions to answer answer then it may reboot at this point to a fresh factory boot if it does not then you may have to make a call to tech support to figure out what is happening this is basically the only suggestion of how to reset the nextbook. best of luck
Tablets & eReaders Logo
I forgot my password for my nextbook tablet. serial no.yfg0414022138.How do I log into my tablet or reboot it to factory settings?
Press and Hold the Volume Up and the Power Button until the Recovery Console appears. Choose Hard Reset.
Dec 14, 2016 | Nextbook Tablets & eReaders
NEXTBOOK 8 ,WITH WINDOWS 8.1, WENT INTO REPAIR LOOP, AND HOLDING POWER BUTTON AND VOLUME BUTTON WONT BRING UP MENU . NEED A FIX BAD
press power, press home button + volume at the same time a menu should appear in top corner , once that shows leave go of all three buttons then with volume press down and when you reach the heading you need press power . YOU DO THIS ONCE YOUR NEXTBOOK 8 IS TURN OFF ( make sure battery is in ).
Dec 23, 2015 | Nextbook Tablets & eReaders
my nextbook 8 will not reset tried holding power button a few secs longer than powering off then restart the device will not start help
Try a reset. Grab a paperclip, look for a tiny hole - probably on the back, straighten the paperclip and gently press it into the hole. It woks for me on my Hudl!!!
Feb 11, 2015 | Nextbook Premium 8 Se Android
lost password
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Oct 26, 2013 | Nextbook Premium Series Next7P12
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
2,268 people viewed this tip
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
