Tip & How-To about Washing Machines
AEG Electrolux Lavamat 50600 is not spinning here are a few work throughs
Download manual
First off that was a link to the online user manual. If this was the first time using the machine did you follow the recommended first time use procedure by following these steps:
Before using your machine for the first time
0 Slightly pull the detergent compartment out of the control panel.
0 Pour about 1 liter of water through the detergent compartment into the washing machine.
When this has been done the ?KO lock can function correctly.
0 Run a wash cycle without laundry (COTTONS 95, with half the amount of washing powder).
This removes any residues from the drum which may have been left during manufacture.
If you have used this prior to the problem occurring try this:
The issues for not spinning are numerous as to what may cause this and it appears to be a lot but most of it is rather simple :
If there is water in the drum you need to follow the pump out procedure and remove water in the drum. Then there may be a "Bend" in the inlet hose. If there is water reaching the drum this is the possible causes and simple to check:
Water is leaking out from under the washing machine.
Fabric softener is not added, compartment for fabric softener is filled with water.
Appliance does not spin, water in the drum.
Washing has not been spun sufficiently, there is water left in the drum.
Door cannot be opened.
The rinse water is cloudy.Possible cause
The inlet hose connection is not tight.
The inlet hose has a leak.
The drain pump cover is not tight.
Washing is caught in the door.
Suction cap in the fabric softener compartment is not correctly fitted or is blocked.
RINSE HOLD selected.
SOAKING program is terminated.
There is a "Bend" in the outlet hose.
Maximum pumping height (drain height 1 m from the position of the machine) is exceeded.
Drain pump is blocked.
The water drainage system is blocked.
The door is locked due to safety reasons
Probably caused by a washing powder with a high silicate content.
Troubleshooting these are the remedies:
Tighten the inlet hose connection.
Check the inlet hose and if necessary replace it.
Tighten cover by turning clockwise.
Abort the program, remove the washing caught in the door, start a new program.
Clean the detergent compartment, fit the suction cap on firmly.
Deselect RINSE HOLD.
Pump out water and set the main wash cycle as desired.
Eliminate the Bend ( it would not allow me to use the proper word here see manual.)
Please contact AEG Service Force Centre, it has a retro- kit available for pump heights above 1 m.
I would definitely try this as it appears to the reset procedure for this machine:
Switch off the machine and pull the plug out of the socket
I would say no less than 20 minutes
but do this while waiting further:
clean the drain pump.
Clean the blockage
Carrying out an emergency emptying
1 Warning! Isolate the washing machine from the main supply before the emergency emptying!
If the washing machine no longer pumps out the water an emergency emptying must be carried out.
Warning! The water, which flows out of the emergency emptying hose can be hot.
First allow the water to cool down before emergency emptying!
0 Put down a flat container to catch the water draining out.
0 Pull down the flap in the left corner of the base strip and remove it.
0 Release the emergency emptying hose from its holder.
0 Pull the emergency emptying hose out a little.
0 Place a container underneath to catch the water.
0 Release the plug of the emergency emptying hose by turning it anti-clockwise and pull it out.
The water will drain out. Depending on the amount of water, it may be necessary to empty the container catching the water several times.
To do this, temporarily close the emergency emptying hose again with the plug. When the water has drained out completely:
0 Push and twist the plug firmly back into the emergency emptying hose.
0 Push the emergency emptying hose back in a little and let it catch onto the holder.
0 Replace the flap in the base plate and close it. When the washing machine is completely empty, the ?KO lock can no longer function correctly. Therefore before the next wash pour in approx 1 liter of water (pour it in through the washing powder compartment)
steps to Clean the drain pump
1 Warning! Switch off the washing machine and pull the plug out of the socket before cleaning the drain pump!
0 First carry out an emergency emptying (see section "Carrying out an emergency emptying").
0 Place a towel on the floor in front of the cover of the drain pump. Surplus water may flow out. 0 Unscrew the cover of the drain pump by twisting it anti-clockwise and pull it out.
0 Remove any foreign bodies which maybe in the pump housing.
0 Check whether the impeller of the pump can be turned. (It is normal forthe pump to turn in steps.) If the impeller cannot be turned at all please contact your local AEG Service Force Center.
0 Replace the cover (insert the ridges on the cover into the guiding slots)and screw on tightly in a clockwise direction.
0 Close the emergency emptying hose, push it in and twist.
0 Close the flap. I sure hope this helps a few people especially the one who I posted this for initially. GOOD Luck! If none of these suggestions work then best to call AEG for servicing, I strongly believe that the Bend in the inlet hose or the drain pump most likely the culprit and or any one of the other issues may well resolve the spin malfunction as well as possibly the main computer may have been goofed due to a slight power surge which unplugging from electric and turning off water for 30 minutes is the basic reset procedure for most electronics ( not all ;but most) while working through these steps should not hurt a thing.
Washing Machines Logo
I am looking for a Free owner manual for a brother lock 925D serger
handbook for compact overlock machine manual de ... - Brother USA
www.brother-usa.com/.../en-US%5CHAD%5CConsumer%5CUsers...
Translate this page
Do not allow to be used as a toy. Close attention is necessary when the sewing machine is used by or near children. 2. Use this sewing machine only for its intended use as described in this manual. Use only accessories recommended by the manufacturer as contained in this manual. 3. Never operate this sewing machine ...
[PDF]Instruction Manual - Brother USA
https://www.brother-usa.com/.../Users%20Manual/UM_PL_2100_EN_238.PDF INSTRUCTION. BOOK FOR SERGER ... Use this sewing machine only for its intended use as described in this manual. Use only accessories recommended by the manufacturer as contained in this manual. 3. Never operate this ... THIS COMPACT OVERLOCK. Your machine is a high quality, easy-to-use product. To fully.
BROTHER 925D HANDBOOK Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Brother Manuals > Sewing Machine > 925D View and Download Brother 925D handbook online. Compact Overlock machine. 925D Sewing Machine pdf manual download.
Feb 11, 2018 | Brother Sewing Machines
How Do i Use this product?
Hi tialeatricee...
Your best bet is to have a user manual to explain all you need to know about this sewing machine.
Sorry I could not find a free user manual for you, but I did find a webpage where you can download one.
Follow the link below
Please take time to rate me
http://www.download-manual.com/shop/Brother-LS-2125-Sewing-Machine-User-Manual-pr-10565.html
Aug 16, 2011 | Brother LS-2125 Mechanical Sewing Machine
where can i get a free instructions manual for my sewing machine
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
And here is a direct link to the Quick Set Up Guide:
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_LS_1217_1520_1717_2125_VX_1435_EN_364.PDF
To view the Owner's Manual with Operating Instructions or the Set Up Guide just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 01, 2011 | Brother LS-1217 Mechanical Sewing Machine
How can I download the user manual
You can view the user guide online on Kodak website but can also download it in PDF. To view it online visit this site.
If you wish to save it as pdf for offline viewing, Diplodocs has it. Click here to visit the website. Just click on the "download this guide" link and follow the procedure to get the download link. You need to enter a code or rate the product before you are given the link. If you have any problem downloading, give me your e-mail and I will mail it to you.
Nov 12, 2010 | Kodak ESP 5 Printer
need a users manual that I can either view online or download immediately to use appliance for 1st time
Go to managemyhome.com and register. This is a FREE service. Once registed, log in and click on the "Home Manager" link at the top of the page. Look for the "Owner's Manuals" link under the drop down menu and follow the instructions on the next page. There are numerous owner's manuals listed in .pdf (Adobe) format that you can download. I hope this helps.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
1,031 people viewed this tip
Top Washing Machines Experts
