Tip & How-To about Cell Phones
How to SIM Unlock the Device CAT (Catapillar) B15 IP67 Rugged Android Smartphone
In order to SIM unlock this device, press and hold the Power key to turn the device off.
Note: A SIM card from another carrier and SIM unlock code are required. You will need to acquire a SIM unlock code in order to proceed.
Next remove the battery cover by sliding the lock to the right, then lift the cover and open at the bottom of the device.
Now remove the battery by lifting from the top of the battery.
Next remove the CBW SIM card by sliding it downward.
Push the new SIM card up into the slot.
now replace the battery by aligning the gold contacts on the battery with the contacts on the device and pressing the battery into place.
next replace the back cover and press the edges until they click into place. Finally slide the lock to the left.
Now you can turn the device on by pressing and holding the Power button.
Then enter the unlock code and tap OK.
You now have a SIM unlocked device.
Cell Phones Logo
What is my phone restriction code of Nokia C3-00.1?
A Nokia C3 unlocked mobile phone works on all GSM networks. The Nokia C3 needs a Nokia unlock code in order to remove the SIM lock that comes on most SIM based cell phones by default. If your Nokia C3 has a SIM lock on it, then it will prevent you from using the mobile phone with any other carriers.I would first recommend you try getting a Nokia C3 unlock code by calling up your current phone carrier. In exchange, they will need your Nokia C3?s IMEI number. Your IMEI number is unique to your mobile device and the Nokia unlock code will be calculated using it. You can get the IMEI number on your Nokia C3 simply by typing *#06# and hitting the enter or send button. If you do not currently have a carrier or cannot get a free unlock code, then I would reccomend trying some of the unlock code websites that I have reviewed below.
Once you have your unlock code, you can begin the Nokia C3 unlocking steps below.
How To Unlock A Nokia C3 (SIM Unlock)1. Power ON your Nokia mobile phone without your SIM card.
2. Now type: #PW+CODE+1# (Where CODE is your Nokia unlock code)
3. Your phone should now show "SIM Restriction Off" and is unlocked.
Note: You must press the * key several times to get the characters for 'P' and 'W'.
If you would like to learn more about the Nokia C3 cell phone, then try reviewing some of the other related reviews below. Enjoy!
Note: The free unlock instructions provided on this site only work with GSM or SIM card versions of the Nokia C3. As always there may be already unlocked versions of this mobile phone, but generally cost a lot more then unlocking it yourself.
Getting a free code from your carrier doesn't always work
So try this unlock service HERE
If it does not support ur phone - then try this WEBSITE HERE
Feb 17, 2011 | NokiaFree Unlock Codes Calculator
Unlock Code for Sidekick II Juicy Couture
How to Enter Unlock Codes on T-Mobile
  1. Press the Menu key.
  2. Scroll to and select Manage Connections.
  3. Select Turn All Connections Off.
  4. Press the red end key or the Escape key to go back to the Home screen
  5. Scroll to and select the Options icon.
  6. Scroll to and select Advanced Options.
  7. Scroll to and select SIM Card.
  8. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
  9. Hold down the Alt key and type in MEP2. Note: When typing in MEP2 the letters/number will not appear on the screen. This Step opens up the Enter Network MEP code box.
  10. Enter the unlock code.
  11. Press the trackball (code accepted should display).
  12. Press and hold the red End key to turn the handheld off and then back on.
  13. Once the device has powered on, follow steps 1 & 2 and select Restore Connections.
Dec 08, 2007 | T-Mobile Sidekick II
uncaught expception
Instructions for unlocking BlackBerry Curve 8520 in UnlockGenie.com
Warning! The Wireless Mode MUST BE OFF before performing the given SIM Unlock instructions in order to avoid causing the device from becoming defective.
How to turn Wireless Mode Off:
1. Scroll to the Airplane Icon (Turn Wireless Off.)
2. Press Select.
3. Wireless Mode will turn off.
How to SIM Unlock the device:
1. Go to the "Options" screen
2. Select the "SIM Card" option
3. Type ALT-MEPD (hold ALT key while typing the 4 Letters, M-E-P-D)
4. Release the ALT key; it should then display a list "SIM, Network, Network Subset, etc..."
5. To select "Network" type ALT-MEPE (since E is the Key that gives 2 when shifted)
6. Release the ALT key, it should then ask for the code
7. Enter the unlock code provided.
Note: In case of difficulties when entering the code please try the alternative instructions below:
Alternative Instructions how to enter the unlock code.
***** You must have a SIM card in your phone to complete these steps. We recommend using the SIM card that your phone is currently working with *****
1. Go to settings
2. Go to options
3. Go to advanced options
4. Go to SIM card
5. Type MEPD (not case sensitive) (you will not see text appear on screen while typing)
6. Does it say Network active? If so your phone is locked
7. Hold the ALT Key while typing in MEPE (not case sensitive) (you will not see text appear on screen while typing)
8. It will say "Enter Network MEP Code, then you type in the 16 digit unlock code, press in the jog dial to confirm
9. Your phone is now unlocked
Jan 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
i had code id but still dont know how to do it , can you teach me how?? tell me step by step how to do it thank you very much for your help
1) Go to Manage Connections
you will see Turn all Connection (OFF)
2) Options
3) Advance options
Select SIM card
4) ID MEPD
on next screen
5) ID MEP2
Type the unloack codeor key
6) Press Enter to finish unlocking
After completing the steps please do Hard Reset
1) Remove the battery cover from the back of the Blackberry smartphone
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover
Hope this information will be helpfull.
Nov 14, 2009 | RIM BlackBerry Pearl 8100
wing
for the pearl: you will need to contact your service provider if you need to unlock the sim to use it with another carrier....it is free but it will take a few days to get the code back if they have tot contact the manufacterer....but you need the 16 diget code......after you get that, go to options, advanced options, sim card, type MEPPD. scroll to sim card, type MEP and pres the ALT key and then the 2 key.
if that doesnt work, instead of typing MEP2, try pressing and holding the ATL key and type MEPPE
if this works, a window will pop up asking for the unlock code....
for the WING: not as hard....just contact the service provider....once you do that....put a foreign sim in the phone and turn it on.....a dialoge box will show up and ask you to imput the 16 number code.....
**NOTE** a forgein sim will need to be in both phones in order for this to work....
Dec 12, 2007 | T-Mobile Wing™ Smartphone
311 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
