Tip & How-To about Cell Phones
Set Up as a Wi-Fi Hotspot for the CAT (Catapillar) B15 IP67 Rugged Android Smartphone
From the home screen, you will tap the Menu key.
Next tap System settings.
Tap More.
Tap Tethering & portable hotspot.
Tap to check or uncheck Portable Wi-Fi hotspot.
In order to change the password or network name tap Set up Wi-Fi hotspot.
The Network SSID, Security type and Password will be displayed and may be edited as needed.
Finally tap Save.
Your Wi-Fi hotspot is now set up and ready to use.
Cell Phones Logo
how do i fix a website?
How to Unblock Facebook at School
Open the Command Prompt on your computer at home (Windows). You can start the Command Prompt from the Start menu. You may not be able to access the command prompt from school, so try this at home first.
  • You can also start the Command Prompt by pressing ? Win+R and typing cmd into the box.
Open Terminal on your computer at home (Mac). You can find the Terminal program by opening the "Applications" folder and then opening the "Utilities" folder.
  • You may also be able to access the Utilities folder from the Go menu.
Type .ping facebook.com and press ? Enter. This works in both the Command Prompt and Terminal. Your system will make a connection to the Facebook website and return the results.
Make note of the IP address. Once the Ping command has run, you will see a series of numbers next to facebook.com in the results. The IP address is four groups of up to three numbers each. Write this number down, including the periods, and take it to school.
Enter the IP address into the browser address bar at school. Press ? Enter to visit the site. Some older blocking systems only block the name and not the IP address, so you may be able to access the site this way.
  • IP Addresses change on occasion, so you may need to repeat these steps after a while.
OR: METHOD 2
Method 2 of 4: Using a Proxy Site
1. Find a list of proxy sites on your computer at home. A proxy is a server that you connect to that allows you to get "outside" of your network. A proxy is also useful because all the work is being done through the browser, so the method works regardless of your computer's operating system.
  • There are several websites that list proxies that you can use. Proxy.org is a great place to start that is constantly updating its
2. Make a list of 10-15 sites to take to school. There's a good chance that proxy listing sites like Proxy.org will be blocked by the school network. Visit the proxy listing sites at home and make a list of 10-15 proxy sites to try at school. list.
3. Try the first site on your list on your school computer. If the site is blocked, try the next one.
  • Proxies that are overused get noticed and blocked, so vary which ones you use on a day-to-day basis.
  • Schools update their proxy site list very often, so chances are that most of your selections will be blocked already. Try to have a large list of proxy sites to try.
4. Select the URL box on the proxy site. Enter "facebook.com" or any other website you wish to visit. Since proxy sites reinterpret the data of website you are trying to access, there's a chance that the site won't load correctly. Most commonly, videos will not load. If this is the case, try again with a different proxy site.
  • Using a proxy site will make browsing significantly slower. This is because the traffic is rerouted through the proxy, reinterpreted and then sent to your location. Be aware that videos and websites may take longer to load, or may not load at all.
Method 3 of 4: Using Your Phone as a Wireless Hotspot
1. Check that your phone can make a hotspot. You will need a smartphone with tethering enabled through the carrier. Many plans in the US allow tethering automatically, though some require paying for the feature to be enabled.
  • Using your phone as the network connection will bypass any restrictions placed on the school network.
2. Open the Settings app on your iPhone or Android.
3. Open the Portable Hotspot/Tethering section. If you can't open this section, then your plan does not support tethering.
  • Android - Tap "More" in the "Wireless & Networks" section. Tap "Tethering & portable hotspot".
  • iOS - Tap "Personal Hotspot".
4. Turn on your phone's hotspot. This will allow you to use it as an access point for a new network.
  • Android - Check the "Portable Wi-Fi Hotspot" box.
  • iOS - Toggle the "Personal Hotspot" toggle on.
5. Get the wireless password for your new network.
  • Android - Tap "Set up Wi-Fi hotspot". Check the "Show password" box.
  • iOS - Tap "Wi-Fi Password".
6. Connect to the hotspot on the computer. Click the computer's wireless network icon and select your mobile phone from the list of available networks. Enter the password from your phone to connect to the network.
7. Connect your phone to the computer via USB if it doesn't have wireless. After connecting your phone with tethering enabled to the computer via USB cable, you should be able to select it by clicking on the network icon in your system tray (Windows) or menubar (OS X).
8.Visit the Facebook website on the computer. Now that your computer is connected to your personal network, you should be able to visit any site without restriction (as long as your personal data plan does not have any restrictions in place).
Apr 22, 2015 | Facebook Social Network
samsung manuals
If plan is enabled:
  1. From the Home Screen, press the Menu Key.
  2. Touch Settings.
  3. Touch Wireless and network.
  4. Touch Tethering and portable hotspot.
  5. Touch Portable Wi-fi hotspot settings.
  6. A message provides an overview of portable Wi-fi hotspots. Touch OK.
  7. Touch Portable Wi-fi hotspot.
  8. A portable Wi-fi hotspot message is displayed. Touch Yes .
  9. You will now be able to share your phone's data connection with a PC or multiple WI-fi enabled devices.
Sep 02, 2014 | Cell Phones
i want to opena hotspot on my sprint samsung sph-m920 i need step by step intructions
  1. Swipe down from the Home screen to pull now the Notifications shade.
  2. Tap on the Settings icon in the top right.
  3. Now find Tethering and Wi-Fi hotspot and tap on it to select it.
  4. In the next menu, tap on Mobile Hotspot.
  5. Turn it On at the top by tapping on the On/Off toggle.
  6. Hit OK on the Attention screen advising you that WiFi will be turned off.
  7. Follow the directions at the bottom of the screen to connect another device
May 14, 2014 | Samsung SPH M920 Transform Android Phone...
how to save battery power on kyocera hydro
Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you. Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it. Tips to save battery life To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
  1. From any home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Battery.
  4. Tap Brightness.
  5. Touch and slide the Brightness slider left to decrease the brightness setting.
  6. Tap OK.
  7. Tap Screen timeout.
  8. Select one of the following options:
  9. 15 seconds
  10. 30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
  2. Tap Settings.
  3. Tap Tethering & Networks.
  4. Tap Mobile HotSpot.
  5. Clear the Mobile HotSpot check box.
  6. Tap the Back key.
  7. Tap the Back key again to return to the 'Settings' menu.
  8. Scroll down to 'PERSONAL,' and then tap Location access.
  9. Clear the GPS satellites check box.
  10. Touch the Status bar and slide it down.
  11. Tap Wi-Fi to turn off.
  12. Tap Bluetoothto turn off.
Change application sync settings
  1. From any Home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'PERSONAL,' and then tap Accounts & sync.
  4. Clear the Auto-sync data check box.
  5. To reduce sync settings for individual applications, select the desired application.
Turn off background data
  2. Tap Settings.
  3. Tap Mobile data.
  4. Tap the Menu key.
  5. Select the Restrict background data check box.
Minimize use of third party applications
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Apps.
  4. Select the application you want to edit.
  5. Tap Disable to turn off the application.
    Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
  2. Tap Settings.
  4. Under 'NETWORK SETTINGS,' tap Mobile networks.
  5. Select or clear the Use only 2G networks check box.
Update to the latest software
  2. Tap Settings.
  3. Scroll down to 'SYSTEM,' and then tap About phone.
  4. Tap System updates.
  5. Tap Check now.
  6. Follow any additional prompts.
Set device to sleep when unused
  1. Press and then quickly release the Power key to set the screen to sleep mode.
  2. To activate the screen, press and then quickly release the Power key again.
Apr 24, 2014 | Boost Mobile Kyocera Hydro Smartphone
Can I make my zio a hotspot
Press the "Home" key if you are not already viewing your Zio's home screen, press the "Menu" key and then tap "Settings."
Tap "Wireless & networks," and then tap "Portable hotspot."
Check the "Portable Wi-Fi hotspot" box to activate your Zio's hot spot feature.
Hope this help!
Sep 06, 2011 | Computers & Internet
291 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
