Tip & How-To about Cell Phones
CAT (Catapillar) B15 IP67 Rugged Android Smartphone Add or Remove a Contact
First off from the home screen, tap the All Apps icon.
Scroll to and tap People.
Tap the Add contact icon.
Tap the preferred contact sync option.
Note: Tapping Sim-only or Phone-only will save the contact to that location only, and will not be backed up to the Google account.
Enter the Name of the contact.
Tap the Phone field, enter the desired 10-digit number, and then tap the phone label field.
Tap the desired option.
Enter any additional information in the desired fields.
Once finished, tap DONE.
The contact is now added.
Tap the Back key.
To delete a contact, tap the Menu key.
Tap Delete contact.
Tap to select the preferred contact.
Tap the Delete icon.
Tap OK.
Cell Phones Logo
how do I access ringtones on alcatel one touch 2001x
To change the ringtone, follow these steps:
Ringtone for all calls
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' then tap Audio profiles.
  4. Under 'PREDEFINED PROFILES,' tap General.
  5. Tap the General Settings icon.
  6. Scroll to '[INCOMING CALLS],' then tap Phone ringtone.
  7. Tap the desired ringtone from the scrolling list.
  8. Tap OK to confirm.
Ringtone for calls from one contact
Note: You cannot assign a ringtone to contacts stored on the SIM card or Phone (device memory).
  1. From the home screen tap all apps.
  2. Tap People.
  3. Tap on the specific contact.
  4. Tap Menu.
  5. Tap Set Ringtone.
  6. Tap on the ringtone, then tap OK.
Mar 27, 2016 | Alcatel Cell Phones
how do I delete or edit contacts in my phone list, I have a cat b15 android
complete steps in case someone else wants to know how to add one as well..
From the home screen, tap the All Apps icon.
Tap the Back key.
Delete:
Tap Delete contact.
Tap OK.
I hopes this helps a bunch of people matter of fact this is one i will add to tips thanks and good luck
Dec 26, 2014 | Caterpillar CAT B15 IP67 Rugged Android...
how can i stop someone from sending me messages.. i don't want to receive their messages
  1. Go to Apps through Home screen.
  2. Tap Messaging.
  3. Tap the Menu key.
  4. On pop up menu select Settings.
  5. Enable Spam Settings under Spam message settings section. When the checkbox next to this option is ticked means the option is enabled.
  6. Tap Register number as spam.
  7. Tap Add (+) icon to add the number.
  8. Enter the required phone number or you can tap Contact icon.
  9. You can pick up the required contact you want by searching or from logs or contacts.
  10. Tap the required contact.
  11. Tap Save button to save the changes.
  12. Now you should see the selected number has been added to the register number as spam list.
  13. Tap Home button to return to the standby mode.
Source:
http://inside-galaxy.blogspot.com/2013/07/samsung-galaxy-s3-how-to-block-unwanted.html
Oct 14, 2013 | Samsung Star GT-S5233 Cell Phone
iv just got a htc wildfire s and i dont know how to delete contacts tht i dont need
If you find duplicated contacts on your phone after Data transfer, simply delete the contact from your phonebook to remove the duplicated contact.
From the Home screen, tap All apps > People > tap and hold the contact you wish to delete > Delete contact.
NOTE 1: All apps can be found when you tap the triangle icon on the lower left corner of the home screen that opens the phone's application menu.
Jul 28, 2011 | Cell Phones
309 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
