Tip & How-To about Office Equipment & Supplies
How to build get lead out of your pencil sharpener!
Your lead is stuck in you sharpener and you have 5 more minutes until your test is collected! I'm here to show you how to get a lead out of your sharpener easy and quickly! First, if you have to remove the lid, then take a something sharp, next find the side of the medal where you can see the lead. Finally take your sharp thing and push up towards the hole where you put your pencil, if it doesn't come out after a bit, lightly bag it on you desk, it should come out fine!
pencil sharpener won't stop running
probably a piece of lead stuck on switch. Unplug unit, shine a flashlight into it and see if you see anything other than the sharpening head(s).
Apr 01, 2014 | X-Acto XActo School Pro Electric Pencil...
Clogged electric pencil sharpener
Usually, this can be cleared up by running a pencil or two through the sharpener.
Feb 16, 2014 | Garden
How do I change the blade on a iPoint evolution pencil sharpener?
Have you tried unscrewing the small circle that you insert the pencil into? Once that part comes off the blade should be more exposed.
Jun 10, 2013 | iPoint 15509: Evolution Axis Pencil...
help with my Royal p70 electric pencil sharpener and I can't seem to get anywhere... A lead is broken in the sharpening gears and I don't know how to take apart the sharpener to remove it.. Ca
Turn sharpener upside down. On the bottom, you will see 6 black dots. Four of them are Legs while the middle two are covers to two screws. Peel the stickey cover off the middle two, exposing two phillips head screws. Once the two very long screws are out, the entire unit will fall out of the casing. You may have to push in the small plastic locking devise at the bottom. Good Luck!
Jan 27, 2013 | Royal Pencilsharpener P70
658 people viewed this tip
jasbo
jasbo
