Tip & How-To about Apple iPhone Smartphone
Quick Fix to an unresponsive iPhone
If your iPhone is slow, unresponsive or just generally laggy and buggy. You can perform a soft reset which should alleviate these issues. It will also solve iPhones that won't power up most of the time.
Hold the power key and the home key for roughly 25 seconds until you see the Apple symbol. This process cuts all power off to the main logic board in your iPhone and simulates if you were remove the battery. Doing this clears any virtual memory clogging up the logic board's RAM (Random Access Memory) which manages all of the programs that are open and running currently and in the background on your iPhone.
Apple iPhone Smartphone Logo
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
Apr 28, 2014 | Cell Phones
how to reset my phone password easily?
Hi Ronquillo,
Apr 28, 2014 | Samsung Galaxy Y Gt-s5360 Pink Factory...
1,432 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
