Tip & How-To about Computers & Internet
Back Up Everything
Constant movement puts computer components at risk, and because of their portability, laptops suffer a lot more wear and tear than desktops. All of that on-the-go use increases the risk of hard drive failure, so make sure you back up the data on your laptop to an external hard drive, thumb drive, or home server on a regular basis. Portable hard drives like the Western Digital Passport Elite make it easy to back up your data on the road
Computers & Internet Logo
clicking noise goes away when braking
Look at the constant velocity joints on that side. When the rubber boot tears it lets road dirt in which fouls the grease and allows premature wear on the cv joint components.
Sep 03, 2014 | Nissan Maxima Cars & Trucks
why oil service required
I will assume you are referring to a light on your instrument panel which says this. If so, you car has a system to remind you of the need for regular oil changes. Your owner's manual will tell you how to turn off that light after you have changed your oil, if you do it yourself. Your service garage will do it if you have them do it. Do not neglect your oil changes or you may suffer engine failure.
Be blessed.
Jun 26, 2014 | 2007 Lexus ES 350
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
Do Motherboards/memory slow down with age?
no never, computer slow due to age because you are downloading more files, using more programs ect..it is recommended that you do a factory reset once a year to clear up everything.
recommended ram today 1GB and more
Jul 30, 2009 | Dell OptiPlex 740 PC Desktop
Computer wear and tear causes slowdowns...how?
Well when your hard drive spins slower than it should be you must replace it. As well as all hardware troubles that might arise through years of use.
But for the software side meaning your registries etc... simply reformating you system will put back to the same speed as it use to be.
Jul 28, 2009 | Dell Computers & Internet
253 people viewed this tip
David Payne
David Payne
