By
h_loberg
Rank: Apprentice
Rating: 98%, 71 votes
posted on Jul 06, 2009
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
Was this helpful?65 people thought this was helpful
Comment #1
posted on Aug 08, 2009
By
rbscarmen
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I unplugged my unit overnight to let it defrost. I plugged back in this morning and can feel the freezer getting cold, but the fan is not kicking on to circulate the air. Should the fan come on immediately, or will it take a while?
Comment #2
By
sibir
Rank: Apprentice
Rating: 78%, 2 votes
I had the same symptoms, but in my case the switch had failed. It had actually popped out of its round housing. Bought a new switch, replaced it and all is well for more than year already.
Comment #3
posted on Aug 05, 2009
where is the defrost heater?
Comment #4
posted on Jul 25, 2009
By
ccc123344
Rank: Apprentice
Rating: 0%, 0 votes
Unscrew the Defrost Heater bracket (2 screws) --- where is it located? from the rear of the refrigerator or remove the inner freezer back panel to get access?
Can you Help with these Refrigerators problems?
GE J Series 18.2 cu. ft. Top Freezer...
refrigerator runs almost constantely just shuts off for a...
Six year old, GE Frost free 18.2 Cft. Compressor does not...
rattling noise
my ge refrigerator will not get below 57 degrees, needs to...
neither the fridge nor the freezer are staying cold. The...
