Tip & How-To about Cell Phones
How to Add a Theme / Change Icons on your iPhone / iPad in iOS 7
I. Jailbreak your iPhone/iPad
To do this procedure you must be jailbroken. If you aren't, you can head to our Jailbreak How To's section and pick the jailbreak for your version of iOS (currently at the time of writing this is 7.0.4). Once done with that procedure and you have Cydia installed, head back here to continue.
*Don't be scared, it's easy to unjailbreak your device.
II. Install Winterboard
1. Open Cydia (if it isn't still open from the section above).
2. Tap Search in the bottom right corner.
3. Type in Winterboard.
4. Tap on Winterboard when it shows up.
5. Tap Install in the top right corner.
6. Tap Restart.
III. Use Winterboard
1. Open Cydia.
2. Search Cydia (either by searching using the search tab on the bottom right, or by tapping the section tab and then Themes (Springboard/Winterboard) icon).
3. Once you find the Theme you want and it says it's compatible with iOS 7, tap Install.
4. Tap Return to Cydia.
5. Open Winterboard.
6. Tap on Themes.
7. Select the theme you want to use.
8. Tap the home button and wait for it to respring the device
9. Repeat steps 1-8 to apply a different theme.
IV. Revert to the Original Apple Theme
1. Open Cydia.
2. Tap on Manage.
3. Tap on Packages.
4. Tap on Winterboard.
5. Tap Modify.
6. Tap Remove.
7. Tap Restart.
Cell Phones Logo
I want to Install GBA4iOS on iOS 9.2 on my iPhone which is unjailbroken
Yes, GBA4iOS for iOS 9.2 can be installed without jailbreak on iPhone. Though it can be tough but instead you try this step by step tutorial:
Install GBA4iOS for iOS 9 2 on iPhone iPad No Jailbreak Cupertino Geeks
Dec 20, 2015 | The Video Game Consoles & Games
Fix "Cannot connect to YouTube" problem from iPhone/iPodTouch
i tried everything on the video, but then after rebooting my device, it went to DFU Mode...should I follow your instructions also regarding the other post on how to restore it? ot its 2 different thing??? - casanova.bedrocks@gmail.com hope you can help me on this one!!!!
Feb 07, 2010 | Apple iPhone 3G
I have an apple iphone 3gs bt have forgotten my pin cde how can i get back onto it
Plug it into your computer, allow it to sync, and then Restore it. It'll update the firmware on your phone though so if it's jailbroken be aware that it'll be un-jailbroken afterwards. There is a jailbreak for the 4.3.3 firmware though so you can just re-jailbreak it.
Apr 27, 2011 | Apple iPhone Smartphone
1,199 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
