Tip & How-To about Faronics Computers & Internet
Deep freeze Alternatives and Similar to Deep Freeze
Http://alternato.net/software/deep-freeze/
1. Comodo Time Machine http://alternativeto.net/software/comodo-time-machine/?latform=windows
2. Reboot Restore Rx http://alternativeto.net/software/reboot-restore-rx/?platform=windows
3. Toolwiz Time Freeze http://alternativeto.net/software/toolwiz-time-freeze/?platform=windows
4. Drive Vaccine PC Restore http://alternativeto.net/software/drive-vaccine-pc-restore/?platform=windows
5. Shadow Defender http://alternativeto.net/software/shadow-defender/?platform=windows
6. Returnil http://alternativeto.net/software/returnil/?platform=windows
7. FarStone RestoreIT http://alternativeto.net/software/farstone-restoreit/?platform=windows
8. Wondeshare Time Freeze http://alternativeto.net/software/wondeshare-time-freeze/?platform=windows
9. Clean Slate http://alternativeto.net/software/clean-slate/?platform=windows
10. Wioski http://alternativeto.net/software/wioski/?platform=windows
11. Safeshield http://alternativeto.net/software/safeshield/?platform=windows
12. SysFreezer http://alternativeto.net/software/sysfreezer/?platform=windows
13. Steadier State http://alternativeto.net/software/steadier-state/?platform=windows
References: http://alternativeto.net/software/deep-freeze/?platform=windows
Shadow Defender
Returnil
FarStone RestoreIT
Clean Slate
Fortres Grand Clean Slate Non restrictive Desktop Security for All Windows...
Safe shield:
Creates a visualization layer to prevent changes to the OS from becoming permanent.
SysFreezer:
SysFreezer is a utility tool designed and developed to overcome system failure. With SysFreezer installed, whenever the system has a problem such as Format, Fdisk, deleting partition or repartitioning hard disk, you only press Reset button and the system will be instantly restored to the state before the problem occurred. In this case, you can avoid re-installing operating system and application programs as well as re-configuring the system. Thus plenty of time for maintenance can be saved.
http://www.sysfreezer.com/
http://cdn.altrn.tv/s/1631ea5f-4bb6-e011-9727-0025902c7e73_5_full.jpg?format=jpg
Computers & Internet Logo
how to disable deep freeze forgot password
and also
and also
you might also look at:
other programs like deep freeze are:
Comodo Time Machine:
IF YOU HAVE A CUSTOMER WHO CONSTENTLY GETS INFECTED OR PLAYS AROUND WITH AREA'S OF THE INTERNET THAT MAYBE HE SHOULD NOT SUGGEST DEEP FREEZE OR SIMULATOR PRODUCTS. IT WILL SAVE HIM ALOT OF MONEY IN THE LONG RUN.
Aug 10, 2013 | Computers & Internet
how to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
I have window s 7 on my pc & I have deep freeze 7 installed on it and i deep frozen my drive c,but after some virus problem my all drive have been deep freezed and now the deep freeze program not running and showing icon & every thing i save to my cop. is going deleting every time. so tell me the easy way to run or unfreeze or uninstall the programe. thank u
To uninstall:
Please comment if the information has been helpful. Thank you and regards.
Aug 25, 2010 | Computers & Internet
564 people viewed this tip
Top Faronics Computers & Internet Experts
David Payne
David Payne
Are you a Faronics Computer and Internet Expert? Answer questions, earn points and help others
