Tip & How-To about Logitech Z-5500 Surround Sound Computer Speakers Thx Home Theater Audio
How to fix a logitech surround sound system
If there is no light on the control, check the mains fuse on the back of the woofer box, if blown, you may have an amplifier ic (tda7294) blown (there are 6 on the big board), replace the ic, if still no sound, mute may be blocked in on position, on small side board there is a transistor (2n4401) connected to a white wire going to the big board, replace the transistor (you may use a bc337)
Logitech Z-5500 Surround Sound Computer Speakers Thx Home Theater Audio Logo
subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
LG TV RT29FC85VW 29" woofer not working
Check the Woofer for continuity and also with an external amplifier.
if there is no issues then the sub-woofer power amp IC can be faulty.
Check the main voltage to the IC, if not present the power section must be traced for a line break, fusible link.
If there is power , then test for input signal to the IC. If so the IC can be the supect.
Oct 28, 2010 | LG Televison & Video
only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
i have a crunch pzi 1000 that blows the main fuse when ever the main power wire is connected and power comes out through the inputs??
hello ! there is a short circuit   on power section  need to  be checked and fixed  some Transistor or IC, diode  burnt  .
The fuse gets blown coz power is reversed back  at primary level ,power supply.
good luck
Oct 03, 2009 | Crunch Powerzone P2125 Car Audio Amplifier
amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
643 people viewed this tip
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
