Tip & How-To about Kitchen Appliances - Others
Appliances Repair Maintenance Hints&Tips From Experts
Having some issues with your washer or dryer?
Dryer is not heating?
Oven not performing like it used to?
Refrigerator making strange noises?
Below you will find some helpful tip to help keep your appliances working their best. If you have any questions, please contact us at (404)903-1453 or via online form. Since every repair situation may be different, below are some of Atlanta Appliances Repair Maintenance Tips.
However, we recommend to go through our checklist below to make sure that the issue with your appliance may not require any repair services:
  • Make sure the appliance is plugged in and turned on. If it is not coming up, check the circuit breaker or fuses.
  • Reset and if it is necessary replace the circuit breaker or fuse and test the appliance again.
  • Make sure the water supply valve is turned on and the machine is getting water to it.
  • Make sure the door or lid is not blocked from opening or closing properly.
  • Always follow instructions for proper use and preventive maintenance - these are usually found in the operational manual that came with the appliance. If you cannot locate the manual, these can frequently be found on the manufacturer's website/contact the manufacturer directly. Appliances overuse/ misuse can lead to serious injury, please always consult with a professional when required.
Atlanta Appliances Repair 404 903 1453 Refrigerator washer dryer oven... hkkzqa5h4z-2-0.jpg" alt="write_tip-whqioz05as2vwqhkkzqa5h4z-2-0.jpg">
Kitchen Appliances - Others Logo
I have a performance problem with my WD440 washer/dryer. All my whites are coming out very grey even after trying whitening products. Any suggestions on how I can improve its performance
The machine itself may be dirty and this consequently is effecting your wash result. Try running the machine on its hottest cycle empty except for a couple of tablespoons of baby bottle sterilising solution or half a cup of soda crystals, this should purge the drum and hoses. There could be a problem with the heating element, whilst its on the hot wash (after about 20mins) just touch the door glass and check it is heating. I run the maintenance wash in my machine every month and this helps performance and also stops bad smells in the washer. If you are having a specific problem with stains on white loads try good old fashion napisan, a couple of tablespoons along with your usual detergent normally works wonders.let me know if this helps
Oct 13, 2011 | Hotpoint Aquarius WD640 Front Load...
my dryer turns on but does not produce heat...any tips on how to fix this ourselves?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 | LG Dryers
clothes dryer drys but no heat(electric dryer)
1. Venting
2. Thermostat
3. Heating element
Jun 16, 2009 | Whirlpool ET8CHEXSQ Dryer
dryer runs has little heat takes longer timer to dry
1. Venting
2. Thermostat
Mar 14, 2009 | Kenmore 62622 Microwave Oven
1,342 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
