Tip & How-To about Vehicle Parts & Accessories
Replace 2008 Versa Hatchback high (center) brake light
The high (center) brake light on our 2008 Nissan Versa hatchback stopped working. We originally thought that it contained standard light bulbs that were replaceable as on most vehicles. But as I have found, the Versa hatchback is *not* most vehicles when it comes to replacing bulbs. It turns out that the hatch high brake light contains no replaceable bulbs. Its LED and the entire assemble must be replaced! So instead of spending a few dollars for replaceable bulbs, one must instead spend upwards of $200 for the part. Sigh.
The first problem was figuring out how to remove the high brake light. The Versa owners manual was totally useless. Scouring the web turned out to be futile. I stumbled onto the solution and thought I would share it for anyone else who has an original version (e.g., not the "Note") Versa hatch.
Even though its not apparent, the high brake light is held in place by 2 nuts. The problem is that those nuts are not visible from inside or outside. The "secret" is to open the hatch and simply remove the interior molding at the top of the glass. Just use your fingers and it will snap right off. After removing the molding you will see that there are two 10mm nuts. Remove those nuts. But the brake light may still not come off because over time the rubber seal may have melted around the assembly. I just used the handle side of a screwdriver to push up on the nuts until the seal came loose and the assembly was able to be removed. BTW, you also have to unhook the electrical connector.
After you order and receive the new assembly, its just a matter of putting it back into the mounting holes, screwing on the nuts, connecting the electrical wiring, and then snapping the molding back into place.
I suspect that Nissan thought using LEDs meant that this light would never need to be replaced and hence no directions on how it was to be done. Likewise, no local dealers stocked the part although I was told it could be obtained in a day or two.
Vehicle Parts & Accessories Logo
neither brake lights work on 2008 versa bulbs appear fine
You have a stoplight switch that is connected to your brake pedal,get a flashlight and push brake pedal in by hand and see if switch is engaging,if not,then you can adjust,if engaging,then switch may be bad.
Sep 13, 2014 | 2008 Nissan Versa
2008 nissan versa right headligh low and high filement on on low and nothing on high
check the wireing that the bulb goes into probley theres a faulty or loosened 1 : )
Jan 14, 2013 | 2008 Nissan Versa
2007 Nissan Versa brake lights not working................. fuse is ok. All other lights are working
Did you check the bulbs ? If they are Ok,then check you brake light switch which is under your brake pedal. Good luck
Jan 09, 2011 | 2007 Nissan Versa 1.8 Sl Hatchback
My nissan versa hatchback standard shift has no reverse lights. I replaced the bulbs and checked the fuse.
you need to check the switching the switching usually comes from the park pawl asm which is found at the shifter rod on the gearbox. the terminals will be corroded inside
Oct 04, 2010 | 2007 Nissan Versa 1.8 Sl Hatchback
how di i get the tail light assembly of to change the brake light bulb on nisson versa hatchback
open the rear hatch and pull carpet away from the lens you want out,you will see four plastic thumb nuts,remove them and pull lens assembly out and replace your bulb
Jan 22, 2010 | 2007 Nissan Versa 1.8 Sl Hatchback
1,375 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
