Tip & How-To about Avaya 4610
How to change your personal message?
You should go to voice mail or 6666 then type your password and then select 3 for greetings. Then you should record your personal message and select to use this for all the numbers that call you.
Avaya 4610 Logo
How do I record my voice mail greeting in my personal cell phone
You didn't say what type & kind of phone you have (iphone or android) or phone service you have (they all do them slightly different). If you dial your own phone number into your cell phone, that should access your voice mail. I have a Sprint Android, so
  1. Press 3 for Personal Options
  2. Press 2 for Greetings
  3. Press 1 to Change Greeting
  4. Press 1 to Record personal greeting or press 2 to select the standard greeting
  5. Press # to End Recording
  6. Press 1 to Confirm Greeting
Change your Sprint personal voicemail greeting
Nov 15, 2016 | Lands Phones
how can i record a voicemail greeting
I assume that you have voicemail on your plan, and your carrier or service provider supports it. First call your voicemail number and wait for the announcement as the whether or not you have any messages. Then next few steps may vary depending on your provider.Enter your password if asked, Voice will tell you you are in main menu, Select personal options number. Select personal greetings. Here you have a choice between extended absence, standard and personal. Select personal, record your greeting, and press # to keep your recorded message. These steps may vary depending on your carrier, but are generally pretty standard, if you simply follow the voice directions.
Jul 24, 2009 | LG Vu Cellular Phone
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
723 people viewed this tip
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
