Tip & How-To about MSA Altair 4 Multigas Detectors - 10085989
How to calibrate the MSA Altair 4
Want to calibrate the MSA Altair 4 Gas Detector or MSA Altair 4X? Here's how:
1. Turn the MSA Altair 4 and MSA Altair 4X on in normal reading mode. Do this by pressing and holding the center button.
2. Once the MSA Altair 4 and MSA Altair 4X is in normal reading mode, you need to send it into calibration mode. Do this by pressing and holding right beeps at you and the screen asks you to zero the monitor (sensor refresh on the MSA Altair 4X).
3. Now that the screen is asking for confirmation, press the center button once to confirm. This will send the monitor into zeroing mode. Now is a good time to set the monitor down, and grab your calibration gas, regulator, and calibration adapter.
4. Open the valve on your regulator. This is a very important step so you do not ruin your calibration gas cylinder. Now screw it in to your calibration gas cylinder. Close the regulator once you hear gas spewing out of it. This is the signal to know your regulator is good to close. Continue screwing in the regulator until it stops. Do not overturn it.
5. Attach the tubing to the hose barb on your regulator. Make sure the tubing is also connected to your calibration adapter.
6. Wait for the screen to come up asking for you to apply calibration gas. Once this screen comes up, press the center button again to confirm. Screw the calibration adapter in to your gas detector. Once it is screwed on, turn on your gas.
7. Make sure your calibration gas values on the screen match what is on your calibration gas cylinder!
8. Once the calibration procedure is completed, turn your gas off and remove the calibration adapter from the MSA Altair 4 or MSA Altair 4X. The screen will go back to normal reading mode within a few seconds.
9. Congratulations! You have officially calibrated your MSA Altair 4 or MSA Altair 4X gas monitor. Make sure to record these readings in your calibration log!
If you come up with an error, the most likely bet is a bad oxygen sensor, but it could be a number of other issues. Feel free to email me.
MSA Altair 4 Multigas Detectors - 10085989 Logo
My detector could not be switched on
Keep the power button pressed for about 3 seconds until it turns on (the middle button). If it doesn't then charge it.
Apr 25, 2014 | MSA 10107602 ALTAIR 4X Multigas Detector...
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
sensor error comes up when turned on
Most likely this is a bad oxygen sensor. We have an informational page up at MSA Altair 4 Gas Detector which should help you find the correct parts. The oxygen sensor is here:
MSA Altair 4 Oxygen O2 Sensor
If there's anything we can help with, like walking you through calibration or how to install the sensor, please send me an email. james@idealcalibrations.com
Apr 12, 2013 | MSA Altair 4 Multigas Detectors - 10085989
Detector saying missing sensor
Most likely it's a missing oxygen sensor. You can get them cheap from my company: MSA Solaris Oxygen O2 Sensor but they sell them all over the place.
Here's a video on how to do the replacement:
Jan 28, 2013 | MSA Solaris Multigas Detectors - 10049297
599 people viewed this tip
Top MSA Home Security Experts
Lawrence Oravetz
Are you a MSA Home Security Expert? Answer questions, earn points and help others
