Tip & How-To about Apple 24" iMac Desktop
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
Apple 24" iMac Desktop Logo
keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
some of the keys work and a few just dont ....I am not sure if the keys are broken....stuck or if my laptop has been dropped or something.It's just not working right
Did someone (not you, of course) spill something (sugar in coffee, tea, cocoa, soft-drink, beer) onto the keyboard? If so, as the liquid dries, the sugar dries up, and gums-up the works.
Get a qualified technician to replace the keyboard.
Apr 10, 2010 | Toshiba Satellite A135-S2276 Notebook
coffee spilled on adding machine
The sugar is the problem, To solve it you must disassemble the keyboard wast it out with hot water let everything dry then reassemble. an awful lot of work for a inexpensive calc.
DickyO
Sep 21, 2009 | Sharp EL-1801P Calculator
Coffee spilled on my Macbook
Hi. Was your macbook open at the time? If os, then the beverage may have gone deeply into the machine. There is some protection from a bit of the elements under the keyboard, but not waterproof protection. also speaker areas and between where the monitor meets the frame. Also the battery compartment and memory compartment are breachable as well. The service center will probably know moisture to a large degree has entered the chassis of your computer. I said probably because it obviously damaged the computer, hence the need for a service center. Coffee gets in there and really can create a problem. Especially if there was mild and sugar in it. Good luck to you. It may be OK. Pretty sure your hard drive is at least.
Jun 14, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
1,138 people viewed this tip
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
