Tip & How-To about Oops Cleaners Ready To Use Spray 500 Ml
How to stop a squeek
For fixing A squeek on your fridge door/kitchen doors/stove door/microwave/or even car try this and save money.We all have cooking spray and if you don,t buy some before the hardware store sells you something that will cost A fortune.Just spray A small amount on t5he squeek and open and close it 4/5 times. If it is hard to get at use A small paint brush.This can also be used on all most anything even your car but only in the summer because it will freeze.Now the squeek is gone and you can use the rest for cooking no waist.Thank you and good luck....
Oops Cleaners Ready To Use Spray 500 Ml Logo
my ge spectra stove stopped working after using the microwave
Is this an electric range? If so try reseting the breaker again. It sounds like you lost one leg of your 220 volts.
Mar 06, 2013 | Kitchen Ranges
Door won't stay closed
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
May 28, 2010 | Sharp R-1610 Microwave Oven
My Microwave starts on its own and wont stop when the time is ove
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Oct 18, 2009 | LG 30" Over the Range Microwave Hood with...
The oven door squeeks
lol sounds like its not just a lube problem but an alignment problem. alot of times the hing has a nylon bushing to cut that noise out. might just want to remove the hing and replace it or try to find a new bushing. these type of problems really ****. seems simple to fix yet it offten takes months of trial and error to cure the problem..... good luck
Jan 14, 2009 | Jenn-Air JES8750 Electric Kitchen Range
GE microwave is not heating food
That crackle is usually a failed high-voltage rectifier diode. It's possible that the magnetron is failing or failed, too, but I would suspect the diode first.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
It's always recommended that you have the hood fan on when cooking on the stove to prevent moisture from entering the controls of the microwave.
Also, I tell my customers to be sure no one ever sprays cleaner directly on the keypad.
But I don't think those are factors in your case.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 26, 2007 | Microwave Ovens
381 people viewed this tip
Top Oops Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Oops Cooking Expert? Answer questions, earn points and help others
