Water leak from door of LG front load washer
By
MNTECH
Rank: Guru
Rating: 94%, 852 votes
posted on Jul 03, 2009
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the
washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Was this helpful?1 person thought this was helpful
Can you Help with these Washing Machines problems?
LG WM-2277HW Front Load Washer
motor locking up,won`t complete spin cycle
water leaking from under LG wm-2277hw
WM2277HW with error code EE, except the first...
just started a load of wash and when the barrel spins, it...
lg washer will not spin. I had the le error last year and...
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
(800) 357-1234
Welcome to Action Appliance Repair. We have...
