Tip & How-To about Pool & Spa
How to ask a question
It is helpful to include all the information possible. If you are asking about a pump, dont just put model ABC, let me know it is a NUMAN pump model ABC.
Just keep in mind, detailed questions get detailed answers
Pool & Spa Logo
i had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
Dec 18, 2012 | Westinghouse " 40"" Class - LCD - 1080p -...
blew a fuse, when i put new fuse in you can hear it turn on and then it starts to pump but does it for a second then stops a second repeatedly
You posted under water heater, but talk about blowing a fuse to the pump.
For the do-it-yourselfer to get best results from fixya, please re-post question with exact information about what you are working on.
Include as much brand and amperage information as possible.
Where is fuse located? Is it part of the pump?
If this is a pump, then say what pump goes to, and what age the pump.
If this this is a HVAC unit, then include that information.
If this is heat-pump water heater, then include age and brand and model number so we can possibly access the manual.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Water Heaters
Windows Xp Home Edition w/sp3
there are multiple ways to tweak your registry to turn it back. here are, maybe, the simple way.
1. copy follow code (between lines but not to include the lines) into your Notepad:
REGEDIT4
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"==dword:000000000
2. save it, for example name it as "abc.txt"
3. rename "abc.txt" to "abc.reg". if you successful rename it. you will see the file icon changes to like a blue magic cube with a paper behind it.
4. double click your "abc.reg". you should get a pop up ask you " Are you sure you want to add the information in xyz(the file path)\abc.reg to the registry? " with Yes and No button. please click yes
5. click OK on this information pop up. You should be all set.
Sep 10, 2008 | Microsoft Windows XP Home with SP2...
607 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
