Tip & How-To about Toro Garden
Toro won't run
All,
I thought my carb was shot, so I replaced it. Still, start but no run (and had to use starting fluid). THEN!!! I noticed the spring to the "rev limiter" (just below and towards rear of carb) was not "tight". The ****** bracket that holds the end of that spring had been bent down ~1/16" and that caused all this heartache. CHECK YOUR REV LIMITER!!!
Garden Logo
How do I fix a mantis tiller that wont start
First, check your fuel lines to ensure they are not brittle from using gas with ethanol. I had to replace my fuel lines last spring.
Prime the carb and pull a couple of times. Pull the spark plug and see if it is wet or damp. Dry and clean the plug. If you have some starting fluid, give it a shot - replace the plug and wire, and give it a pull.
Mar 09, 2015 | Mantis Garden
I have trouble starting a toro walk behind mower
All,
I thought my carb was shot, so I replaced it. Still, start but no run (and had to use starting fluid). THEN!!! I noticed the spring to the "rev limiter" (just below and towards rear of carb) was not "tight". The stupid bracket that holds the end of that spring had been bent down ~1/16" and that caused all this heartache. CHECK YOUR REV LIMITER!!!
Aug 18, 2014 | Toro Power Lawn Mower
I don't think my tiller is getting any juice to the sparkplug. I changed the sparkplug and air filter, checked the oil and gas, but it still won't start.
disconnect the kill wire on the motor and then see if you get spark. If so its your switch, if not it either points or electronic coil or regular coil or condenser problem did you gap the pints correctly and was there a problem b4 you changed the points.
May 03, 2011 | Troy-Bilt Pony Garden Tiller
waveraider will not start with out a shot of starter fluid
you need to replace the carb kits if u have not already done that riva racing youll find them change the plugs first always
May 26, 2009 | Yamaha 12V Air Pump
1,039 people viewed this tip
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
