Tip & How-To about Fisher Price Laugh and Learn Smart Bounce and Spin Pony
Challenging Fix-It's!
If Frustrated by a fix-it step or two, STOP! Breath Deeply. Put it down for 15 min and calmly reflect, have a refreshment, walk for 20-30 mins or distract yourself with TV/Radio/Read. Then attempt again, you will be surprised!
Fisher Price Laugh and Learn Smart Bounce and Spin Pony Logo
how do i get the %$#@ thing to work???
Hi Steve:
You're sounding frustrated.
Breath deeply and slowly, be calm, we're here to help.
Tell us what it is, and describe the problem. Tell us what you're trying to do, and exactly what happens. Things like,
when I turn the key
- NOTHING happens (maybe dead battery) to
- IT CLICKS (maybe bad solenoid) or
- IT JUST SPINS OVER ((Maybe fuel or spark problem)
Be calm...... It will be OK...... we'll help
Mar 30, 2015 | Cars & Trucks
I have a TC5000 When I am walking for about 5 to 15 min. It stops. and when I pull the safty pin out and put it back in its ok for about the same time and quits again.
Check to make sure steps are being counted. This tells the machine someone is using it. The step counter is in the center of the steps on most machine. It will sometime count intermittenly. Another thing to check is if the machine seems to be laboring more when you start to walk on it. This could be a sign that it needs lubricating. Check manual for lubricating proceedures.
Nov 16, 2009 | Bowflex Treadclimber
dryer will not stay on
thanks for the question. how long does the dryer run for 1 min 10 min 15 min if it runs for 10 min or more you could just have lint covering the motor so it cant breath vacuum the dryer clean the venting this could cause this problem thanks the appliance doc
Sep 15, 2008 | GE Dryers
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
975 people viewed this tip
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
