Home | All Products | Digimax D53 Digital Camera | Tips
Short battery life with AAs or camera won't even power up on new...
Daveemtb
By Guru Daveemtb
Rank: Guru
Rating: 87%, 243 votes
posted on Nov 09, 2007
Helpful
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
Was this helpful?
Yes
No
10 people thought this was helpful
Comment #1
posted on Apr 25, 2009
stevoholic31
By Apprentice stevoholic31
Rank: Apprentice
Rating: 0%, 0 votes
This camera sucks. It takes horrible pictures, you know the 2 or 3 you can snap before the batteries die. It does not matter what kind of battery you use, you will have very little time to take any pictures worth while. The video recorder on it is by far the worst. I should have never bought this piece of garbage.
Comment #2
posted on Feb 04, 2009
sn2112
By Apprentice sn2112
Rank: Apprentice
Rating: 0%, 0 votes
Fuji a350. When I got the camera, it took many many photos(50-100) with alkaline and rayovac 2500nmh. After the camera sat for a month or more, batteries were dead. OK fine. Since then, I would get about 10 pictures and the battery level low would come on, and soon shut off. Someon at Best Buy told me leaving alkalines in the camera Damages the battery level sensor, and tells the camera that even new batteries are low. Is this true? Can this problem be fixed. I did not see any re-set buttons on the camera.
Comment #3
posted on Dec 18, 2008
wmcot
By Guide wmcot
Rank: Guide
Rating: 0%, 0 votes
The problem with digital cameras is that the charging of the flash circuitry can draw 1 to 2 amps momentarily from the batteries! Most batteries can't handle the high current. That's why batteries that test good will still not work in a camera. You can take them out of your camera an put them in a flashlight or portable audio player and they will probably work fine.
The cheapest route is to buy a set of good AA Ni-Mh batteries (2000mAh or higher - the higher the better) You can often find a set of 4 batteries and a charger together for around $20.00.
Lithium are better than alkaline, but they are expensive and not rechargeable. You'll save a fortune if you go the Ni-Mh route.
The only time I use alkalines in my cameras is during an emergency (like my Ni-Mh set has been drained.) They'll work for awhile and even longer if you don't use flash.
Comment #4
posted on Oct 13, 2008
Chebbi
By Apprentice Chebbi
Rank: Apprentice
Rating: 0%, 0 votes
What a poor performance,i hadnt thought the the battery life is so silly,i went to a function and inorder to shot pics the camera was on only for 10 min,it made me to change the batteries every 10 minutes,If i have known this earlier definitely i would not have taking it.So please any who is reading this message dont buy Panasonic DMC-LS70,or if you already have it its your BADLUCK.
Comment #5
posted on Sep 17, 2008
Shamshley
By Apprentice Shamshley
Rank: Apprentice
Rating: 0%, 0 votes
I'm having the same issue with this camera. The battery doesn't last, and it isn't compatable with many other batteries.
I've notcied that with my camera, the flash is always way too bright, and it has the red eye flash. Also the screen lighting was really bright, and I think that maybe the battery might be draining quickly because of that.
I think that maybe ebay it is the answer?
Comment #6
posted on Aug 20, 2008
subendu
By Apprentice subendu
Rank: Apprentice
Rating: 0%, 0 votes
Hi guys.. try NiMH rechargable battries with 2500 mAH or 2700 nAH. These batteries have really long life.. I have a Canon S5 IS and I can take around 200+ photos by these batteries..
Comment #7
posted on Jun 25, 2008
sunawalker
By Apprentice sunawalker
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with my olympus branded camera i can only take 3 -4 pictures ,although i bought new charcable batteries they don't seem to work either..
Comment #8
posted on Jun 13, 2008
magen432
By Apprentice magen432
Rank: Apprentice
Rating: 0%, 0 votes
i need help with my samsung digimax a503 i have brand new alkiline batteries in it and it says low battery and turns off please someone help im going crazy with out my camera
Comment #9
posted on Apr 19, 2008
maddog44094
By Apprentice maddog44094
Rank: Apprentice
Rating: 85%, 1 votes
stick with the lithium batteries, and other will drain too fast.
Comment #10
posted on Apr 07, 2008
Jrussell789
By Wiz Jrussell789
Rank: Wiz
Rating: 83%, 86 votes
It is a waste of money to use Alkaline batteries in a power hungry digital camera. The only reason you get them included with new cameras is to provide you a way to turn on your camera and see how it works. The market is highly competitive and they cannot afford to raise their advertised selling price by including NEEDED rechargeables and a charger to use them.
Read any camera manual and they will tell you to get rechargeables. Now there are NiMH Hybrid Precharged batteries that will hold their charge longer over time, it is even more a waste of money to not use them. Buy name brand batteries. Digital china junk, sold right on the shelf beside 'real' batteries, make it easy to make mistakes.
Of course, the best solution is to buy a newer camera that uses Rechargeable Lithium. One half the weight of NiMH and hold a charge much much longer, ie, will not self-discharge any where near as fast as AAs sizes.
Comment #11
posted on Apr 02, 2008
Cintris
By Apprentice Cintris
Rank: Apprentice
Rating: 0%, 0 votes
I have a similar problem. The batteries not only do not last very long but the camera is now getting very hot under the body, not the batteries. I have the Dimage Z2 4.0Mega Pixels. I am also having trouble with it focusing correctly. Granted I do not know as much as I wish I did about this camera and possibly it is set on macro or something like that but I can only get a good close up photo. Since the batteries say they are exhausted I can't do much to fix it until I get new ones. Any suggestions as to why it would get hot like that?
Comment #12
posted on Feb 19, 2008
Bronchobuck
By Apprentice Bronchobuck
Rank: Apprentice
Rating: 77%, 4 votes
@ Kath17:
It sounds like the charger. If you bought new batteries and the problem persists it has to be 1 of 2 things:
1. Faulty charger
2. Faulty camera
@ bamdrew, SamTed & kcCasey
It sounds as though you have a similar problem to the known issue with Hewlett Packard's HP Photosmart 635 (see FixYa for more).
The HP 635 has a fault whereby the 'date/time' battery continually tries to charge itself by drawing on the main AA batteries. I physically removed the faulty battery by applying Nspektor's (from FixYa) solution today and it seems to have fixed my camera. I have had a fresh pair of Varta 'Ready2Use' 2000mAh nimhs in the camera for the last 3 hours and I can still start the camera with no problem. Previously this would not be possible.
Regarding disposable lithium batteries, there is an alternative. The next generation of nimhs called 'ready to use' come pre-charged and hold 80% of there charge for months. As the name suggests they can used straight from the packet. Normal nimhs discharge at about 1% per day. As of Feb '08 'ready to use' nimhs are 2000mAh maximum, but will probably increase in capacity in the future.
I have only used Varta 'Ready2Use' 2000mAh AAs & 800mAh AAAs but they worked straight from the packet and I haven't charged them since I bought them about 5 weeks ago.
I use them as backup batteries for the numerous normal nimhs I have, so when e.g. the mouse batteries go flat, I can pop in the 'ready to use' batteries while I charge the normal nimhs. Eventually I will buy more 'ready to use' batteries and use them for main use and one set for backup as above.
As a long term user of rechargables due to concern for the environment, and also the cheaper cost, the new 'ready to use' batteries are great. They cost the same as normal nimhs so there's no reason not to get them.
I hope this helps.
Comment #13
posted on Feb 01, 2008
Scargo
By Wiz Scargo
Rank: Wiz
Rating: 83%, 34 votes
I am a semi-pro, long-time photographer and I just learned from a long-time pro that lithium-ion (Li-ion) rechargeables are the best and better than nickel-hydride (Ni-Mh)batteries and far, far better than nickel-cadmium (Ni-Cd) batteries. They are more expensive but the Li-ion and Ni-Mh batteries don't have the "memory" issue that Ni-Cds have.
They perform better (by keeping the voltage at a more constant level) until they poop-out and don't care when you choose to pop them back into the charger to get them back up to a full charge.
All rechargeables slowly but constantly drain off some of their energy, just laying around. They are not a good choice if you don't use your camera or flash very often (or for a smoke detector, for that matter). Then I would go with disposable lithium batteries. They also hold up better and longer in the cold.
Comment #14
posted on Jan 28, 2008
Kath17
By Apprentice Kath17
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago the camera is fine but we have not used it for a few years as the battery (lithium recahrgeable) would show on charger as being fully charged but would only last a few minutes. Thought it was a battery problem so just recently bought a couple of new batteries and the same thing happens. Does anyone have the same problem? Could it be the charger?
Comment #15
posted on Jan 22, 2008
Steve5
By Guru Steve5
Rank: Guru
Rating: 90%, 543 votes
We're finding excellent performance out of the Energizer Lithium AA batteries. They're not rechargeable (sorry environment) but they do last about 7 times longer than alkalines (1/7 th the waste, yahoo). Price is about 4X higher than alkalines. Cost per shot works out less than alkalines.
Comment #16
posted on Dec 19, 2007
bamdrew
By Apprentice bamdrew
Rank: Apprentice
Rating: 0%, 0 votes
My old Olympus C4040 is also having major battery issues (going on 5 years of ownership, problems apparent at 3.5 years in). I can't use it anymore as it immediately states that new or fully recharged batteries are low. I've been thinking about taking it apart and investigating, or bending up the battery contacts to see if thats the problem.
Comment #17
posted on Dec 01, 2007
SamTed
By Apprentice SamTed
Rank: Apprentice
Rating: 0%, 0 votes
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the camera three years and this just started. They no longer make them, of course. I expect there is some circuit problem draining the batteries.
Sam
Comment #18
posted on Nov 27, 2007
kcCasey
By Apprentice kcCasey
Rank: Apprentice
Rating: 0%, 0 votes
With my camera, that doesn't help much. The camera drains batteries within 10 minutes. You have to hurry up and take whatever picture you want and even if you use rechargeables it is a real pain to have to replace the batteries that often. There must be something wrong with this camera. It has done this from the very beginning and with the Panasonic batteries that came with the camera. A total bummer. Had I known this I would NEVER HAVE BOUGHT THIS CAMERA (PANASONIC LUMIX DMC LZ2)
Can you Help with these Digital Cameras problems?
Samsung Digimax D53 Digital Camera
I can't get the camera to turn on it has the lens out and...
the pictures on my samsung digimax d53 are very blurry,...
Hi, Inside photos are fine but outside photos are coming...
i lost my cd to down load program to my new laptop to...
how can i repair my digimax d53 cameras. the flash won't...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
