Tip & How-To about Garden
How to keep a nice green lawn.
I find it is wise to sharpen the lawn tractor or even the lawn mower blades at least every three weeks depending the hours your unit has run. You will find the grass looks better being cut with sharp blades .Dull blades tears the grass and your lawn will bruise and turn yellow as well
Garden Logo
my john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
The mower vibrates once the blades are engaged.
Hi, you might want to pull the blades off and check the blades and adapters for cracks or breakage or wear. if not the spindle assemblies could have the excessive wear to them. You did not say how old the unit was so hope this helps
Oct 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
305 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
