Tip & How-To about Sony 182556522 1-825-565-22 SUB WOOFER (PCVA-SB1) Insure proper part number before ordering. Computer Speakers
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
sub woofer will not work
Check the speaker of the sub=woofer. If found OK, check and replace the damaged component/s at its audio output section circuit. Contact any service technician. Electro help
Apr 04, 2015 | Samsung HW-FM45C 280W Soundbar with...
circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
SUB WOOFER PROBLEMS
design u r aucostics properly
Jan 10, 2009 | Infinity BU-80 Speaker
1,037 people viewed this tip
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
