Tip & How-To about Kenmore Grilling
Ignitor doesn't click, spark or light gas
When my 2-year-old grill quit supplying a spark to light either the grill or the side burner, I removed the battery/start button and noticed droplets of water inside.
So I removed the ignitor unit. When I shook it, I could hear water sloshing inside, probably because I'm too lazy to put the cover on the grill after using it.
The part was going to be about $40 with shipping.
I shook out all the water I could, but still no spark.
Remembering a tip I'd heard about wet cell phones, I sealed the ignitor unit in a bag of dry white rice and left it on the grill in the Florida sun for a couple of days. Lots of condensation showed up on the plastic bag.
Shocking discovery: after two days in the plastic bag, I shook out residual rice, replaced the battery and button, pushed it, and the sparks tingled my fingers pretty well! Lots of volts!
Also works fine in the grill again. Probably works on all brands of grill ignitors...
Grilling Logo
A minor scratch will not do much harm to your image unless you use higher f-stops.Buff might help if its done by the canon themselves but mostly once an element is scratched , its gone for ever. any attempt might deteriorate the image quality even fogging your image in certain parts. using fine glass polishing powder can be used very delicately but its pretty technique sensitive and you might almost ruin the whole lens element.
If your images are fine, then don't bother or else better change the element for full from the canon.Local shops might not give you the best result.
Feb 04, 2013 | Kenmore Grilling
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have tried to light it up , but there is no spark , and I do not hear a click on the rottisserie knob, please help.
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights instead (something we rarely use!!). We can manually light the grill but it is only 1 1/2 years old - help! Thank you! DMac
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Apr 09, 2011 | Kenmore 700 sq. in. Cooking Area Gas Grill...
My grill will no longer lights all three rows. I
My Weber is almost as old as yours and I had a similar problem. I removed the grates and cleaned the inside and checked the holes along the sides of the burners. The burners tend to build up cooking residue along the edge a restrict the gas flow. Try an aggreesive cleaning of the interior.
Jun 11, 2010 | Weber Genesis Silver B Grill
My Weber gas grill is less than a year old. The
gas regulator make sure all burners are off when you connect bottle... the units have a leak sensor and will stop the gas coming out because it thinks you have a leak when you connected the bottle. now try hooking up the bottle again with all the burners closed incl. the side burner and the infa red. It will work o.k. then
Apr 07, 2010 | Weber 3820301 Gas Grill
1,010 people viewed this tip
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
