Tip & How-To about Bosch Coffee Makers & Espresso Machines
Bosch tassimo T65 - water draining in to drip tray possible cause and resolution
I had a problem on my Tassimo T65 where water was entering the bottom drip tray through the small hole at the rear. It seems many people have this problem but after researching on line there is little help although I found on this sit how to take the coffee maker apart and from that thread the possible cause for my own issue.
So if your machine seems to be leaking from the small drain hole to the rear of the drip tray try this before you think it is either in need of specialist repair by Bosch at a cost almost the same as a new machine or before you start to take it apart and have a look yourself.
CAUSE - The water is coming from the drain hole because the pressure valve at the top of the machine is blocked with calcium deposits through prolonged use without descaling sufficiently.
SOLUTION - Purchase a good quality coffee machine descaler. Sit the whole coffee machine in a tray or large oven tray so you can collect the overflowing descaler throughout the process, it's not economical to waste this solution. Remember to clean down and dry the coffee maker each time.
Use at least half strength descaler do not water it down more than 1:1
Follow the descaling process by inserting the yellow disc and holding the start button down for 3 seconds.
Repeat this process several times, recovering the fluid leaking in to the tray and cup or container. If you start to see small lumps being dispelled in to the cup try to remove these for further descaling.
After several cycles you should notice that the leaking or flow of water from the bottom drain hole becomes less until it stops. To force the dissolving scale out of the pressure valve try running the normal clean cycle but with the descaling solution, the flow is longer and will help flush the restriction.
After a number of descaling and clean cycles the leak or flow from the drain hole will have stopped, if not continue till it does.
Note: I ran cycles for about 2 hours with periods of rest to allow the solution to do its work.
Now the leak or flow has stopped clean out the reservoir and replace with clean water and run at least 4 clean and rinse cycles.
i hope this works for you and now enjoy your coffee.
Coffee Makers & Espresso Machines Logo
how to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it ยท Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
I have an SA12059 Windchaser portable a/c. After using it and rolling it around, the top condensate tank drips lots of water. I tried to drain the bottom tank via the hose, but the top tank doesn't seem to drain into the bottom one.
There is not actually a top tank, just a drip tray with little drain holes that become easily clogged. After removing the rear cover of the unit and cleaning thoroughly, you can use a can of air (like the ones to dust pc's) wth the little straw attachment to try to clear te clogged drain holes in the tray below the evaporator. If your unit froze up condensate may have overflowed into the fan area. Let the unit defrost, and run it in fan mode for awhile to dry this moisture out.
Sep 01, 2013 | Windchaser PAC9 Air Conditioner
1,598 people viewed this tip
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
