Tip & How-To about Home
I found an easy solution to removing a stuck stopper recently when I was fixing my kitchen sink and the stopper became vacuum-stuck. Instead of trying to pull on it (which will not work since the pressure is too great), or trying to release the vacuum by prying up an edge with a knife or other instrument (which would damage the stopper or sink), I used a (clean) toilet plunger to plunge the stopper out. Simply place the plunger squarely over the opening where the stopper is stuck and give it two good plunges. I got the stopper stuck several times while fixing the sink and this trick worked every time for getting the stopper unstuck. Make sure you are using a plunger that's cup-shaped (stands upright on its own), and not the kind that has a bulb at the end.
