Tip & How-To about Computers & Internet
Authentication errors
With the internet of everything just around the corner, more and more devices mean more and more standards. when one is faced with an authentication error, and if they've triple checked the network key for accuracy, its time to find the right encryption method starting in this order.
wpa2 aes
wpa2tkip
wpa aes
wpa tkip
wep is last resort
Computers & Internet Logo
Authentication problem? can not connect to internet
If you are facing authentication problem from your existing network then there might be a chance that someone has changed the password and if you are connecting to a new network then you must have entered the wrong password.
Jan 05, 2017 | Computers & Internet
ok so ive been everywhere trying to find proxies and so on. basically a way to get around websense at my school. i always get my work done early and im tired of sitting around doing nothing. so i need some sites that will actually work. every single one ive found and tried has faild. Help please?
Face book sign in requires user name and password for each member. Troupe arising to either as forgotten details required to signing prevents successful entry to member spaces on the site. The face book site provides alternative means to access member areas. For example, the type space buttons on the site makes resetting for produce new passwords or misplaced usernames. First type search www.facebook.com to arrive at the website. The spaces that make sign with username and password should be displayed at which point. An alternate button that may be recognized from observation with clicks should allow restore user accounts. Usually prior to establishing face book accounts, backup passwords would be requested either as second password with many possible means to recollecting missing details. Requesting missing details once successful would be emailed to the account holder's email address where retrieving to make religion comes possible. Reset details after changes were made to the account should be acquired from the account holders email address where several possible features concerning the account would have been communicated. Face book sends to the member's emails address the link related to the site as authenticity to confirm the reset process. The email send is required to complete the reset process once unconfirmed makes the account compromised. Also the computer network connections make possible inability to logon. For example, malfunctioning computers or networks least acquires face book as an internet site. Ascertain that the computer with network devices is in functioning mode prior to log on to face book or websites. Usually, a malfunction caused by networks would require disconnecting from computer internets to reestablish the structure setup. The reasons are because interconnected devices become idle after several tasking responses. Especially with pad subscriptions, time outs are likely to prevent over charges. Once the network experiences malfunctions may be temporary request to reconfigure dormant or over active device. Power off to allow devices to reestablish networks. Also, usually, when computer that derive connectivity experience malfunction with the dominant computers. The terminal computers momentarily loose networking. An unsuccessful attempt at logging into a web site requires contacting support experts of the website either as report to malfunctions or request to retrieve missing links. Browse through the reaming details of the network to acquire contact details either email, phone or chat lines to make communications only from another functioning device possible from which resolution is achievable.
Feb 07, 2011 | Facebook Social Network
I am having troble signing in
Feb 07, 2011 | Facebook Computers & Internet
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
I am having a sound problem with my XP hp pavilion dv1000,
did you see a audio voulem control icon on the right side in the corner on your desktop?
and 1st.
try to use head phone , plug in your laptop, see everything works ok ?
A............ working good, that means the speaker of your laptop may have problem, hardware problem. (no one can do anything for you)
B............still no sound, maybe the software/driver problem, try to uninstall the old driver, and reinstall again.
Dec 30, 2008 | HP Pavilion dv1000 Notebook
1,170 people viewed this tip
David Payne
David Payne
