Tip & How-To about HP Pavilion dv6000z Notebook
My hp pavillion g6 wont boot
By pressing f11 repeatedly during start up will pop up dialog box to access system recovery image. But if the system image has been deleted accidentally, check if you have a friend with the same model copy the recovery file from his computer. You will locate the recovery file when you open my computer. Then connect the usb device and try restart your system using 11. If it fails enter setup and change the first boot device to usb and still press f11 for the system to see the system image file. Otherwise look for original os cd for your computer. Nnamdi
HP Pavilion dv6000z Notebook Logo
how do I return my msi wind u180 to factory settings
Use the recovery partition on your MSI laptop to recover its original factory settings. Recovering your MSI laptop to its original factory settings will resolve problems with instability that you may be experiencing as a result of missing system files that were accidentally deleted. Recovering your MSI laptop to its original factory settings will also completely remove any viruses on your computer's hard drive that you were unable to remove with anti-virus software. Fortunately, you can wipe all of the information off your laptop's hard drive and start with a clean slate.
Instructions
  • 1
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager."
  • 2
Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings.
  • 3
Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the size of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes.
  • 4
Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system.
How to Recover an MSI Laptop to Original Factory Settings eHow
Oct 09, 2014 | MSI Wind Top Ae1920 1800 Mhz Intel Atom...
return msi ge620 to factory settings
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager." Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings. Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes. Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system. Hope this helps.
b>
Jan 14, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
I want to reboot my entire system so it starts from scratch, how do I do this?
If your system does have a recovery partition (typically says press f11 for recovery during boot if you have one) Reboot the pc, press f11 during the asus screen. The system restore utility will guide you through the rest.
If your system does not have a recovery partition
Take your system restore or operating system disc, Put it in the cdrom, reboot the computer.
When your pc starts back up (during the asus logo screen) During this screen there is usually a key sequence you can press to pop up the alternate boot menu. Typically the key is esc, f8 or f10. If one of those is right it will bring up a second menu asking what to boot from, select your cdrom. The cd will boot and your system restore disc will guide you through the rest..
Aug 28, 2011 | ASUS Computers & Internet
How do I access the hidden partition to reinstall operating system?
Turn on or restart your notebook, then press F11 while your notebook is
starting.
3 Insert the Operating System Recovery CD/DVD when prompted. The System
Recovery program starts.
Click a system recovery option
Full System Restore (Destructive) reformats the hard drive and
restores the system software as it was when you purchased your
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
contents of the hard drive to the C:\My Backup folder and installs
a new copy of Windows XP. This option saves your existing data
files, but all programs must be reinstalled and the program settings
reconfigured. You need at least 4 GB of hard drive space to use this
restore option.
5 Click Next. The System Restore - Format and Recover dialog box opens.
6 Click Yes. Files are restored to your hard drive. When file recovery has
finished, the System Restore dialog box opens.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
After you restore your system, it will
appear with the same files and programs
it had when it shipped from the factory.
You still need to download Windows
updates and antivirus updates to bring
your notebook’s software up to date.
8 Reconnect your Internet cable and all USB peripheral devices. You are
done.
Apr 03, 2010 | Gateway MX6214 Notebook
black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
May 15, 2009 | Compaq Armada E500 Notebook
2,639 people viewed this tip
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
