Tip & How-To about Hypercom Optimum T4220 Dual Terminal w/Internal PIN Pad
KNOW YOUR FUNCTION CODES!
There are over 100 function codes for the terminal. Know at least the basic 1001. Batch Review03 Terminal Reset05. Batch Info/totals10. Date and Time65. Mail Order Phone Order71. enable/disable Pritner73. Reprint any Transaction82. Printer Test89. Card Reader Test95. Network Status
Hypercom Optimum T4220 Dual Terminal w/Internal PIN Pad Logo
My Credit Card Terminal was batching out and it ran out of print paper, so I had to change it right then. It cancelled my batch, so did my batch process? Do I need to re-enter the credit cards from th
you would have to call your processing company and ask them to check if they sales completed the settlement. you can also run a report on your terminal by pressing the purple key marked reports, if the sales are still in the terminal they will show on this report if they settled it will not have information.
Oct 07, 2014 | VeriFone VX 510 Credit Card Terminal
Program a tax table
OUR SYSTEM INFO
ZONTALK TID:00024495
OS VERSION :QJ0012AO
APPL VERS:2.09
RAM SIZE :2048
FLASH SIZE :4096
AVAIL RAM :1231300
SERIAL NO:214-825-406
PTID :28580696
PART NO :M25152936EUC
APPL SIZE :567140
APPL DATE :22/12/2011 09:51:48
SDK VER:3.5.0
UCL VER:2.21.1
TCP/IP VER :4.21.0
EMV VER :ver 5.0.6
MODEL NO :V510G
CREDIT CARD
TERMINAL ID :00024495
MERCHANT ID :960692000
BATCH :693
D/N DATE 27/6/2014 22:41
DATE 28/6/2014 13:15:20
Jul 21, 2012 | Royal Alpha 9500ml Cash Register
How to change the time
You can find the full manual here:
http://www.obfs.uillinois.edu/common/pages/DisplayFile.aspx?itemId=918000
But here's the part about changing the time:
System Reset-DATE or TIME
To change the terminal Date and/or Time:
1. Press the More function key.
2. Press the green Enter button until the terminal screen displays Other Set Up.
3. Enter the password (last six digits of the Merchant ID# or 998877).
4. Press the Enter button.
5. Press the More function key.
6. Press Enter until the terminal screen displays Date/Time.
7. Press Enter for Date (MMDDYYYY), enter the correct Date, and press Enter. Go directly to Time, and bypass Date, by pressing Enter twice.
8. Press Enter for Time (HHMMSS), enter the correct Time, and press Enter.
9. To Exit, select the red Cancel/Clear button twice.
Mar 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
my credit card machines show ivn batch sew...dont know what it mean
There was a miscommunication between your terminal and your processor. You need to call them to verify batch totals and possibly update some info inside the terminal.
Feb 14, 2011 | VeriFone Omni 3200 Printer
nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
688 people viewed this tip
Top Hypercom Computers & Internet Experts
David Payne
David Payne
Are you a Hypercom Computer and Internet Expert? Answer questions, earn points and help others
