Tip & How-To about Cell Phones
How to Root any Android Device(EASY)
Source: http://www.cnet.com/how-to/how-to-easily-root-an-android-device/
Rooting is the Android equivalent of jailbreaking, a means of unlocking the operating system so you can install unapproved (by Google) apps, update the OS, replace the firmware, overclock (or underclock) the processor, customize just about anything, and so on.
Of course, for the average user, rooting sounds like -- and can be -- a scary process. After all, "rooting" around in your smartphone's core software might seem like a recipe for disaster. One wrong move and you could end up with bricked handset.
Thankfully, there's a new Windows utility that makes rooting a one-click affair: Kingo Android Root. It's free, and based on my initial tests with a Virgin Mobile Supreme, it works like a charm. (Be sure tocheck the compatibility list before you proceed, keeping in mind that although the Supreme wasn't on it, the utility had no problem with it.) Here's how to get started.
Step one: Download and install Kingo Android Root.
Step two: Enable USB debugging mode on your phone. If it's running Android 4.0 or 4.1, tap Settings, Developer Options, then tick the box for "USB debugging." (You may need to switch "Developer options" to On before you can do so.) On Android 4.2 and later, tap Settings, About Phone, Developer Options, and then tick USB debugging." Then tap OK to approve the setting change.
Step three: Run Android Root on your PC, then connect your phone via its USB sync cable. After a moment, the former should show a connection to the latter.
Step four: Click Root, then sit back and wait while the utility does its thing. The aforementioned Supreme took all of about two minutes, including the automated reboot at the end.
And that's all there is to it. If you decide you want to reverse the process, just run Android Root again, connect your phone, then click Remove Root.
With that done, now you can take advantage of options like USB On-the-Go to make your unexpandable phone expandable . Hit the comments to share your favorite tricks for a rooted Android phone.
Cell Phones Logo
I'm trying to jailbreak my SGH-1747 but every time I go to towering it says my phone isn't supported. How do I fix?
H Derek. The i747 is a gaalxy S3, if I'm not wrong.
OK, when you post the qeustion sking that you need help to jailbreak an Android device, believe me, you will hardly get help from the community. This will send a message to the Androids fan that it must be your first time trying to root an Android device.
I will leave a link here for you to read which it will explain step by step on how to root your device with Kingroot. A another one with everything from root to flashing and customizing.
http://forums.androidcentral.com/t-galaxy-s-iii-rooting-rom-s-hack-s/466427-guide-how-root-t-galaxy-s3-sgh-i747-m-kingo-android-root.html
http://galaxys3root.com/category/galaxy-s3-root/
Nov 25, 2015 | Cell Phones
How do I jailbreak my galaxy S4 without erasing all the data?
hi this is how to ROOT not Jailbreak your galaxy s4
First of all there is no jailbreak for android but there is root
and to root your device you can first backup your data on your pc
then search on google for towlroot install it then open it then click on make it rain and it will root your phone
but if it doesn't work or your phone is not supported then you have to root from your pc I will provide you a link to download root for s4 on pc
How to Root Your Samsung Galaxy S4 Or Almost Any Other Android Phone In...
Aug 10, 2015 | Samsung Cell Phones
how to jailbreak an android Motorola X
Bailey-
Are you wanting to root or unlock the bootloader? We support unlocking bootloader on many of our recent devices. Head over to http://www.motorola.com/developers for details. Rooting and unlocking bootloader void the warranty on your device.
Mark
Motorola Support
Apr 16, 2015 | Motorola Mobility Moto X
How to root my android phone
Rooting an android phone is nothing but be careful, follow only right guides to root your android phone, I am giving some guides below -
Root Your Android Using Kingo Root Android Working
How to Root your Android using Framaroot How to root your android device
You may also like ....
How to earn Money Online from YouTube
Jun 14, 2014 | Android Apps
root my Android SII Galaxy
Hello, mess82
You can safely root your Samsung Galaxy S2 Android device. Simply follow the detailed step by step instructions available in this site and you're done!
Regards!
Sep 11, 2012 | SOTI Inc SOTI MobiControl
726 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
