Tip & How-To about Computers & Internet
Clean and cool laptops are happy laptops...
Many laptop hardware system failures can be directly attributed to excessive heat build up on vital internal components on the main board. After a couple years of fairly regular use dirt, hair, and dust will build up on the heat sync gradually cutting off all air flow. (btw you can have a spotless home or office and this is still true) You may hear the CPU fan staying on more frequently and working harder and harder.
Many folks purchase base fans which run on USB... but my philosophy is that if you think you need one, then cooling system probably needs to be serviced. (and drawing more current out of the USB can just add to power demands)
The easiest way for a user to prevent this is to service it starting when it's only a few months old. We want to back flow it with compressed air. Flip your laptop over. Locate the CPU cooling fan and air intake. Using a paper clip lock the fan through the intake so that we don't spin it at a zillion RPM. Using compressed air blow into the fan outlet. Should be at the fan area on the side or back. Remove paper clip making sure fan spins free.
If your laptop is more than a couple years old and you suspect low flow due to restrictive heat sync. You may want to have a qualified technician service it. When servicing laptops more than a couple years old I always disassemble them completely. If clogged severely and you try to back flow it, you can lock the fan up with debris causing fan failure.
Always keep air intake on bottom clear. Do not use directly on bed, carpet, sofa, or any restrictive area (also with contaminates) without a flat hard surface to maintain constant air flow.
May your laptop stay cool and happy for years!
Computers & Internet Logo
main control board
Cyclic resetting can be the protection circuit kicking in due to one or more of many possibilities.
Some common failures which can cause self-protection:
Insufficient ventilation/ cooling (overheat);
Excess dust (arcing);
Shorting components (overload);
Open circuits (components, tracks or dry solder-joints);
Incorrect load (eg speakers blown or loose wires).....
Oct 01, 2017 | Vizio VF551XVT 55 in. HDTV
cant switch my ps3 on ,the red light is flashing
Therecan be a variety of issues that cause the Playstation 3 red lightproblem, but in most cases it comes down to the system overheating. Themore it overheats the more damage is created internally to themotherboard and other functioning components. This can be caused simplyby a flaw in the system or by obstructions to the fan vent such as awall, floor, or excessive collection of dust.
Read more: http://www.articlesbase.com/hardware-articles/how-to-fix-playstation-3-red-light-flashing-effective-tips-and-tutorials-1792732.html#ixzz15vPr4GAv
Under Creative Commons License: Attribution
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
I get a blank screen and 4 beeps what's the problem?
This could happen when the RAM contact is not proper, may be due to dust. Remove the memory modules from DIMM slot, clean it (no moisture please) and reinsert it. This could mostly solve your issue.
Please come back and rate my solution if it turns helpful for you or also if you need more clarifications. Thnx
Apr 01, 2010 | Fujitsu LifeBook A6110 PC Notebook
Real time clock failure. Invalid configuration
..plz do check the following as in order:..
the Hardware part:..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..change if required..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | Intel Computers & Internet
470 people viewed this tip
David Payne
David Payne
