Tip & How-To about Smelly Washer 216 Dishwasher/Disposal Clnr 12 Ounce
Smell in laundry
Just run another cyle adding vinegar to the washe.
Smelly Washer 216 Dishwasher/Disposal Clnr 12 Ounce Logo
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
I have kenmore elite washer, when done with spin cycle water is still in bottom of drum. hose's are all clear, could it be the pump is bad?
could be pump and also could be beging of a suds lock meaning high concetration of soap in pump housing creating air pockets which cant be pumped out check pump and hoses do the feel slimy residue run hot water cyle and pour in a cup of vinegar in washer and run a load
Jan 27, 2011 | Kenmore Elite 45986 Front Load Washer
there is a lot of lint especially on black clothes after wash with 6.5kg Front Load Bosch Washing Machine WAE20261AU. How to fix this issue?
Before the wash ad few cups of white vinegar to the washer half filled with water.let it run for sometime and then drain off fully.
Now for the wash add a cup of white vinegar along with the detergent. clothes be pit in inside out, cotton and polyester have different tendencies. so as towels.
So keep them for seperate washing to avoid more build up.
Sep 24, 2010 | Bosch Washing Machines
we have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
Large Appliances
start by cleaning out the filter in bottom,
remove the access panel bottom 3 screws , open filter , some excess water will spill ,
clean it out,
next clean under the rubber flap around front of drum.
run borax through a cycle.
run clorox in a cold cycle
the issue may be that the back of the drum is coated with waxy goop from using too much softener,
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
493 people viewed this tip
Top Smelly Washer Dishwashers Experts
Are you a Smelly Washer Dishwasher Expert? Answer questions, earn points and help others
