Tip & How-To about Vehicle Parts & Accessories
How often to change the motor oil in your car, regardless of how much % of oil life is left?
Never go over 6,000 miles of driving on any motor oil, including synthetic oil. The oil filter cannot pick up 100% of metal particles out of the oil. The smallest metal particles pass right through the oil filter and go through to your entire engine. Each day that you drive, more metal particles get into the oil. After 6,000 miles of driving, there is enough micro sized metal particles to start causing excessive wear on your engine. Millions if not trillions of these metal particles go into your engine every minute. The additives in synthetic motor oil will last 15,000 miles, but these additives do not remove any of these micro sized metal particles. Just because synthetic oil costs a lot more, does not mean that it will last any longer than regular oil. Yes, synthetic oil will help your engine to last up to twice as long, as compared to regular oil, but only if you do not drive more than 6,000 miles.
Vehicle Parts & Accessories Logo
how many miles does the 1998 oldmobile intrigue run until it needs a oil change?
6000 miles ,every 6000miles then every thrid oil change do the oil filter and use the cheapest oil you can buy
Sep 27, 2010 | 1998 Oldsmobile Intrigue
what weight oil do I use
Usually the recommended oil is marked on the filler cap, also look in the owners manual. Most modern cars use 5W-30.
Jun 25, 2009 | 1998 Lexus ES 300
603 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
