Tip & How-To about Ovens
Cleaning an oven
Put ammonia in your roasting dish and leave in your oven overnight. Make sure you use a mask. the next morning wipe out your oven with soapy water and rinse. grease will just wipe off your racks etc
Ovens Logo
Aqua lift doesn't clean the oven.what should I use or do.
Spray with Easy Off. Put a glass dish of cleaning ammonia in the middle of the oven. Leave overnight. The next day everything will rinse off. Have plenty of ventilation and wear long gloves.
Maytag AquaLift Self-Clean Technology - YouTube
2q==? 1:55 https://www.youtube.com/watch?v=LdBzf6DHyHI
  1. Similar
Mar 23, 2012 - Uploaded by The Home Depot Watch Associate Joey demonstrate Maytag's AquaLift self-clean technology. If you'd like an oven that ...
AquaLift self-clean oven technology - YouTube
9k=? 1:09 https://www.youtube.com/watch?v=4mdiD1yid1Y
  1. Similar
Jan 6, 2012 - Uploaded by Whirlpool Corporation Whirlpool Corporation is introducing AquaLift™ self-clean technology, a first of its kind cleaning solution to self ...
AquaLift TM Technology Cleaning Methodology - YouTube
z? 3:48 https://www.youtube.com/watch?v=zfKLpQdZD5c
  1. Similar
Feb 3, 2012 - Uploaded by Whirlpool Appliance Repair Self Help Videos AquaLift TM Technology Cleaning Cycle & Cleaning Methods.
Whirlpool® Cooking - AquaLift™ Self-Cleaning Technology - YouTube
z? 0:21 https://www.youtube.com/watch?v=N1-Gty3LUik Mar 6, 2014 - Uploaded by WP Canada Now it takes minutes, not hours, to get a great clean that's odour free with Whirlpool® AquaLift™ Self-Cleaning ...
Aqualift really does work - YouTube
2q==? 2:33 https://www.youtube.com/watch?v=5GRImKNE3BA
  1. Similar
Aug 20, 2012 - Uploaded by apreston123 This video shows the aqualift self clean in action. Video starts after the 40 minute cleaning cycle has finished ...
Jan 10, 2018 | Ovens
beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
remove grease from oven
Place 1/4 cup ammonia in a glass container and put it in your oven when it is cool. DO NOT TURN THE OVEN ON. Leave overnight. The next morning, take a damp rag and the grease and soil should wipe right out. You can use some fresh ammonia to get the rest of the residue out if you need to. I hope this helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Profile JTP56 Electric Double Oven
aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
603 people viewed this tip
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
