Tip & How-To about Video Game Consoles & Games
Xbox 360: Install games for better performance
Install a game on your hard drive
  1. Note After you insert the disc, the default action is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
  1. Insert the game disc into the disc drive.
  2. From the Home hub, select the game in the drive tray, and then press X on your controller.
  3. Select Install.
  4. A progress indicator appears while your game is being installed on your hard drive.
  5. Note Installing an Xbox 360 game might take 12 minutes.
Video Game Consoles & Games Logo
hi my name is chris and I have a game that I bought last year and i am 11 years old. when i got this there was no scratches but when my family was moving and i was at school at that time my brothers were so clever that they boosted eachother up got my disc and god knows what they did with it. The game was nba live 10 and it was for my xbox 360 console i tried everything toothpaste but didnot try really scratch remover stuff i even tried what my dad recomended and it was a lense cleaner. but did not work due to how many scratches there were on it from before please if you have anything to recomend i would really appreciate that. thank you
It is possible that your game is scratched up enough that you can't play it directly on your xbox 360... BUT you might still be able to play it is you can save it to your Xbox 360 hard drive. You might need to try it a few times to get it to read and work but try following these instructions for installing the game from your CD directly onto your Hard drive. You will still need to have the CD in your Xbox 360 to play but it will be reading from your hard drive if you can install it. Good luck:
To install a game on your hard drive loadTOCNode(2, 'moreinformation');
    Note After you insert the disc, the default option is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press the Y button on your controller.
  5. Select Install to Hard Drive.
  6. A progress indicator appears while your game is being installed on your hard drive.
To play a game from your hard drive loadTOCNode(2, 'moreinformation');
  3. Select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
To delete a single game from your hard drive loadTOCNode(2, 'moreinformation');
  1. Insert the game disc for the game you want to delete from your hard drive.
  2. Go to My Xbox, and then select the game you want to delete.
  3. Press the Y button on your controller.
  4. Select Delete from Hard Drive.
To delete multiple games from your hard drive loadTOCNode(2, 'moreinformation');
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Select Hard Drive.
  4. Select Games.
  5. Select the game you want to delete.
  6. Select Delete.
To clear space on your hard drive loadTOCNode(2, 'moreinformation'); If there is insufficient space on your Xbox 360 hard drive, you will receive the following message:
Not enough space to install this game. It needs [space needed] free space to install. Do you want to clear space? (YES/NO) Click YES to view a list of games that you can delete. After you clear enough space on your hard drive, you can install the new game.
Jul 20, 2011 | Video Game Consoles & Games
when putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the console or the game and can it do any harm
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  4. Press Y on your controller.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Jul 18, 2011 | Microsoft Xbox 360 Console
my 360 will let me play a little bit of a game at a time. after playing maybe 5 or ten min or so it will freeze up. the last two times that it froze up it asked me two clean the disc, or contact xbox3660 support. the disc itself is in great shape. i still cleaned it anyway and still the same result. what do i do?
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Notes
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked fine. I thought I needed a hard drive because when my friends brought over their hard drives, Black ops worked fine. I bought one but it still doesnt work please help.
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Notes
Jul 17, 2011 | Microsoft Xbox 360 Console
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
565 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
