Tip & How-To about Battery Biz Computers & Internet
Battery lenovo G570
Extend your life laptop battery:
1. LENOVO G570 Remove the battery from the computer and disconnect the power cord if you do not plan to use your laptop for more than two weeks. Because the battery will discharge during storage out of the computer, it must be recharged every three months to expand its capacity and cycle to avoid problems loading or autonomy in the future.
http://www.chargeursbatterie.com/c-Lenovo_37/p-LENOVO-G570_13286.html
Computers & Internet Logo
laptop black screen
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening.
I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen.
After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
or if wont start
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer.
There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
Aug 08, 2013 | Computers & Internet
why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
lennovo g570 bios cmos not responding for enabling password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 11, 2012 | Lenovo G570 Notebook
My Toshiba leptop battery runs out and goes from a 100% to 0% after 30-60 minutes. Is there a way to fix this, or it has to be checked by a professional?
Normally when the battry gets to that point the only way to fix it is to get a new battery. If you have had the computer for less than a year the battery may still be under warranty.
Once a battery develops what is called "memory" it is almost impossible to alter. Memory develops over time when the battery is not drained all the way and then allowed to recharge completely. Newer battery designs have preventives for this but still may happen.
Apr 07, 2011 | Toshiba Satellite A300-0CF035 Notebook
I have a laptop LENOVO (3 y.o). Now it seems that the Battery % is decreasing despit its being connect to the Power. Do i really need to Purchase a New Battery?
sounds like you do, if you just want to use the laptop on mains power you can just disconnect the battery completely and the laptop will work fine
Mar 09, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
842 people viewed this tip
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
